The PowerScan PM8300 cordless laser scanners are Datalogic Scanning's premium line of rugged industrial handheld data collection products for linear codes. The mobile phone-like keyboard allows for the manual entering of bar codes that are not readable and enables easy management of simple code-quantity applications like inventory, picking, receiving, etc.
Narrow band radio communications with Datalogic's STAR Cordless System provides the key to increased productivity and flexibility in the workplace. It offers scalable solutions from simple point-to-point applications to networking capabilities combined with seamless roaming for complex installations.
The PM8300 readers feature Datalogic's exclusive 3 Green Lights (3GL) for superior good read feedback. The patented 'Green Spot' directly on the code and dual Good Read LEDs on the top and back of the cap adds increased visibility at any angle. Superior reading performance is enhanced by Datalogic's patented PuzzleSolver technology for fast and accurate reading of standard, poorly printed and damaged codes.
The PM8300 reader's mechanics have been developed and tested to withstand extreme environmental conditions maintaining consistent reading performance without degrading performance or reliability. Its ergonomic enclosure is lightweight and well balanced to ensure optimal operator comfort during scan intensive operations. A built-in metal tether hook for suspended applications ensures workplace productivity.
Robust durability
Designed to withstand the rigors of daily use, the Datalogic PowerScan PM8300 operates efficiently in temperatures ranging from -20°C to 50°C, ensuring reliable performance in a variety of environments. -
Efficient scanning
Equipped with a visible laser diode, the PM8300 offers a scan speed of 35 scans per second, making it suitable for fast-paced settings. Its ability to read barcodes at a pitch of 55 degrees and a skew of 60 degrees enhances its versatility in capturing data. -
Versatile compatibility
The Datalogic PowerScan PM8300 is compatible with PC systems, facilitating easy integration into existing setups. Its decoded TTL output ensures seamless communication with a wide range of devices.
- Datalogic PowerScan PM8300 - barcode scanner
- Barcode scanner - handheld - RF - decoded
- Black, yellow
- Minimum Bar Width
- 3 mil
- Scan Element Type
- Visible laser diode
- Scan Speed
- 35 scan / sec
- Connectivity Technology
- Wireless
- Wireless Connectivity
- RF
- Power
- DC 10 - 30 V
- Battery
- 1 x Lithium Ion
- 6.9 cm x 11.4 cm x 20.7 cm
- 395 g
- 3-year warranty
- Black, yellow
Barcode
- Interface Type
- RF
- Minimum Bar Width
- 3 mil
- Scan Element Type
- Light Source Wave Length
- 630-680 nm
- Scan Mode
- Single-pass
- Scan Speed
- 35 scan / sec
- Max Working Distance
- 5000 cm
- Skew (Degrees)
- 60
- Pitch (Degrees)
- 55
- Print Contrast Signal (PCS)
- 15%
- Decode Capability
- Code 93, Code 39, UCC/EAN-128, Code 49, ISBT 128, GS1 DataBar, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Code 16K, Interleaved 2 of 5, MSI-Plessey, Pharmacode
- TTL Decoding
- Decoded
- Wireless
- OK Notification
- Beeper, LED indicator
- Triggered, waterproof, Puzzle Solver Technology
- RF
- 1 x RS-232 - DB-9
- Included Accessories
- Cradle
- Cables Included
- 1 x serial cable - external
- IEC 825-1/EN 60825-1 class 1, IEC 60529 IP65, RoHS, FCC CFR21 Part 1040, WEEE, IEC 60825-1
- Power Device
- Power adapter - external
- Voltage
- DC 10 - 30 V
- Battery
- 1 x Lithium Ion
Software
- Software Included
- Datalogic Aladdin
- 6.9 cm
- 11.4 cm
- 20.7 cm
- 395 g
- Limited warranty - 3 years , Limited warranty - cable - 90 days
- -20 °C
- 50 °C
- 0 - 90%
- Drop Specification
- 2 m to concrete
