Datalogic QuickScan Mobile QM2131 Barcode Scanner
Quicklinx: BRTWWS00 Mfr#: QM2131-BK-433K1
Type: Barcode scanner
Form Factor: Portable
Compatibility: PC
£119.66 ex VAT
£143.59 inc VAT
The QuickScan QM2131 imager's extra-wide field of view and extra-long scan line makes reading long bar codes in closer distances much easier. The sharp and highly visible scan line makes the scanner more user-friendly to use, while the enhanced depth of field enables bar codes to be read at an intuitive distance. The QM2131 linear imager provides secure radio communications with no risk of interference from Wi-Fi infrastructure and very low sensitivity to obstacles like concrete walls, wood or metal shelves.
  • Enhanced performance
    The QuickScan QM2131 imager's extra wide field of view and extra-long scan line makes reading long bar codes in closer distances much easier. The sharp and highly visible scan line makes the scanner more user-friendly to use, while the enhanced depth of field enables bar codes to be read at an intuitive distance.
  • Cordless features
    The QM2131 linear imager provides secure radio communications with no risk of interference from Wi-Fi infrastructure and very low sensitivity to obstacles like concrete walls, wood or metal shelves. A microUSB port on the scanner foot allows an auxiliary method for battery recharging and host download configuration, and also allows the product to be used without the cradle.
Datalogic QuickScan Mobile QM2131 - barcode scanner
Barcode scanner - portable - RF(433 MHz) - decoded
Minimum Bar Width
4 mil
Scan Element Type
Linear imager
Scan Speed
400 scan / sec
Wireless
Wireless Connectivity
RF
1 x Lithium Ion
9.1 cm x 4.1 cm x 16.3 cm
190 g
3-year warranty
Barcode
Interface Type
RF(433 MHz)
Minimum Bar Width
4 mil
Scan Element Type
Linear imager
Light Source Wave Length
610-650 nm
Scan Speed
400 scan / sec
Skew (Degrees)
70
Pitch (Degrees)
65
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, GS1 DataBar, GS1 DataBar Composites, GS1 DataBar Expanded, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked, GS1 DataBar Stacked Omnidirectional, UPC-A, UPC-E
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
Waterproof
RF
1 x USB
USB powered base station
IP42
1 x Lithium Ion
9.1 cm
4.1 cm
16.3 cm
190 g
Limited warranty - 3 years
50 °C
Compatibility: PC
Brand: Datalogic
