Datalogic Data Logic Touch 90 Light - USB Kit
Quicklinx: 8SJ1WS00 Mfr#: TD1120-BK-90K1
Type: Barcode scanner
Form Factor: Handheld
Compatibility: PC
£48.69 ex VAT
£58.42 inc VAT
The Touch TD1100 series of linear imaging contact readers represent the Datalogic ADC solution for customers who require a cost-effective solution for close contact bar code reading without sacrificing quality and performance.
Designed for low throughput applications within multiple markets, the Touch TD1100 readers provide the guarantee of contact reading with an excellent reading performance on virtually all linear bar codes, including damaged or poorly printed codes.
Small, lightweight and low on energy consumption, the Touch TD1100 readers continue to provide robustness and a 1.5 m drop resistance, which is typically included in a higher range of products.
An innovative 'read-thru' holder provides the Touch TD1100 readers with hands-free reading capability on documents or small items. Datalogic's Aladdin configuration software provides user-friendly features that simplify the start-up procedure, even for inexperienced users.
  • Efficient scanning capabilities
    The Datalogic Touch TD1100 can read various GS1 DataBar formats with a minimum bar width of 4 mil, enabling efficient processing of different barcode types.
  • Robust environmental performance
    This scanner functions effectively within a temperature range of 0°C to 50°C and operates in humidity levels from 5 to 95%, allowing it to be used in a variety of settings.
  • Stable wired connectivity
    Featuring wired connectivity technology, the Datalogic Touch TD1100 ensures a stable and reliable connection for seamless operation in various applications.
  • Clear operational feedback
    Equipped with an audible beeper and LED indicator, users receive immediate feedback, facilitating efficient workflow and ensuring successful scans.
Datalogic Touch TD1100 90 Light - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
4 mil
Scan Field Width
15 cm
Scan Element Type
Visible laser diode
Scan Speed
256 scan / sec
Wired
6.7 cm x 10.4 cm x 17 cm
153 g
5-year warranty
Barcode
Interface Type
USB
Minimum Bar Width
4 mil
Scan Field Width
15 cm
Scan Element Type
Visible laser diode
Light Source Wave Length
640 nm
Scan Mode
Single-pass
Scan Speed
256 scan / sec
Skew (Degrees)
70
Pitch (Degrees)
65
Print Contrast Signal (PCS)
25%
Decode Capability
Code 39, GS1 DataBar, EAN/JAN-13, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
ESD (electrostatic discharge) safe
1 x USB - Type A
Holder
1 x USB cable - 1.8 m
RoHS, IP30
Electric Current Required
20 mA (standby), 100 mA (typical)
Software
Software Included
Drivers & Utilities, Datalogic Aladdin, OPOS/JavaPOS Drivers
6.7 cm
10.4 cm
17 cm
153 g
Limited warranty - 5 years
50 °C
5 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Datalogic
