Your basket is empty
Datalogic PD8330 Tethered Scanner (Standard Range
Quicklinx: 7SCLWS00 Mfr#: PD8330
The PowerScan 8300 series readers' ergonomic enclosures are lightweight and well-balanced ensuring optimal operator comfort during scan intensive operations. Multiple good-read feedback features and a built-in metal tether hook for suspended applications ensure workplace productivity. The PowerScan 8300 series readers' superior reading performance is enhanced by Datalogic's patented Puzzle Solver technology for fast and accurate reading of standard, poorly printed and damaged bar codes.
The PowerScan 8300 series readers' mechanics have been developed and tested to withstand extreme environmental conditions maintaining consistent reading performance. Hard shocks, dust and water and adverse temperature conditions do not affect product performance or reliability.
The PowerScan 8300 series readers are offered with a full set of accessories and have multi-interface capabilities built in featuring the most popular interfaces. The Datalogic Aladdin configuration program provides user-friendly features that simplify the start-up procedure, even for inexperienced users.
Datalogic PowerScan D8330 - barcode scanner
Barcode scanner - handheld - keyboard wedge, RS-232, USB, wand - decoded
Minimum Bar Width
7.5 mil
Scan Element Type
Visible laser diode
Scan Speed
35 scan / sec
Wired
295 g
Barcode
Interface Type
Keyboard wedge, RS-232, USB, wand
Minimum Bar Width
7.5 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
630-680 nm
Scan Speed
35 scan / sec
Max Working Distance
10 m
Skew (Degrees)
60
Pitch (Degrees)
55
Decode Capability
EAN/JAN, Code 93, Code 39, Code 49, ISBT 128, ISBN, GS1 DataBar, Code 32, Codabar, Code 128, Code 11, Code 16K, UPC, MSI-Plessey, ISSN
TTL Decoding
Decoded
Wired
OK Notification
Beeper
Puzzle Solver Technology
1 x USB , 1 x RS-232 , 1 x barcode scanner - wand , 1 x keyboard wedge
FCC Class A certified, EN55022 Class B, AS/NZS 3548, RoHS
295 g
-30 °C
50 °C
Drop Specification
2 m
