Datalogic Gryphon M4400 2D HC 433MHZ
Quicklinx: BBNYWS00 Mfr#: GM4400-HC-433
Featuring Datalogic's STAR Cordless System, the Gryphon GM4400 imager provides bi-directional communication, which allows data to be reliably transmitted from the reader to the host system and vice versa. The Gryphon GM4400 batch mode capability allows thousands of codes to be stored in its memory. These features, combined with a 60,000 scans per charge Lithium-ion battery, allow uninterrupted scanning with unlimited mobility.
Perfect for both handheld and presentation reading, the GM4400-HC 2D imager features Datalogic's Motionix motion-sensing technology which detects the natural actions of the operator to automatically switch the scanner into handheld or hands-free scanning modes. Datalogic's unique two-position cradle allows for presentation style reading while the "scan-while-charging" feature adds extended productivity.
The deep-red illumination of the Gryphon 4400 imagers eliminate the irritating "flicker effect" allowing for comfortable all-day usage. The highly visible 4-dot aimer provides a clear indication of the reading area, making targeting codes quick and easy. The Gryphon 4400-HC 2D readers can decode virtually any 1D and 2D bar code symbology and can read codes from LCD monitors, cell phones, smartphones and other mobile devices.
Datalogic Gryphon I GM4400-HC 2D - barcode scanner
Barcode scanner - portable - RF(433 MHz) - decoded
Healthcare
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Scan Speed
60 frames / sec
Wireless
Wireless Connectivity
RF
1 x Lithium Ion
7.1 cm x 10 cm x 18.1 cm
245 g
3-year warranty
Healthcare
Barcode
Interface Type
RF(433 MHz)
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Frame Rate
60 frames / sec
Skew (Degrees)
40
Pitch (Degrees)
40
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, Code 39, QR code, MaxiCode, Aztec code, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Postnet, PDF417, Data Matrix, PLANET, Australian Post, China Post, Japanese Post, Kix (Netherlands) Post, Korea Post, MacroPDF417, Royal Mail, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Composites, GS1 DataBar Stacked, China Han Xin Code
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator, vibration
Antimicrobial protection, Green Spot technology, Datalogic STAR Cordless System
RF
RoHS, JavaPOS, OPOS, IEC 60825-1, IP52
1 x Lithium Ion
7.1 cm
10 cm
18.1 cm
245 g
Limited warranty - 3 years
50 °C
0 - 90% (non-condensing)
Drop Specification
1.8 m to concrete
