Efficient scanning
Equipped with a visible laser diode, the Datalogic QuickScan L D2330 barcode scanner ensures accurate and efficient scanning with a speed of 100 scans per second. Its ability to read a wide range of barcodes, from Codabar to UPC, makes it versatile for various applications. -
Durable design
Designed to withstand the rigors of daily use, the Datalogic QuickScan L D2330 features a robust form factor that can endure drops from up to 1.5 m to concrete. This durability ensures reliable performance and a longer lifespan for the device. -
Optimal compatibility
The Datalogic QuickScan L D2330 offers seamless integration with PC systems, thanks to its wired connectivity technology. This compatibility, combined with decoded TTL, simplifies setup and use, making it a convenient choice for various scanning needs.
- Datalogic QuickScan L D2330 - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Black
- Minimum Bar Width
- 5 mil
- Scan Field Width
- 13.9 cm - 26.9 cm
- Scan Element Type
- Visible laser diode
- Scan Speed
- 100 scan / sec
- Connectivity Technology
- Wired
- 6.7 cm x 7.1 cm x 17 cm
- 128 g
- 3-year warranty
- Black
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 5 mil
- Scan Field Width
- 13.9 cm - 26.9 cm
- Scan Element Type
- Light Source Wave Length
- 650 nm
- Scan Mode
- Single-pass
- Scan Speed
- 100 scan / sec
- Skew (Degrees)
- 60
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 30%
- Decode Capability
- EAN/JAN, Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 128 Full ASCII, Code 39 Trioptic
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- Reduced Space Symbology (RSS)
- 1 x USB
- Cables Included
- 1 x USB cable
- TUV, ISO 9001, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, EN 60950, NOM, PCT, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, MIC, RoHS, EN 60825, IEC 60825-1
- Electric Current Required
- 30 mA (standby), 100 mA (typical)
- 6.7 cm
- 7.1 cm
- 17 cm
- 128 g
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 5 - 95%
- Drop Specification
- 1.5 m to concrete
