The xStack DES-3552 by D-Link is a high-performance, managed, stackable 28-port Layer 2 Fast Ethernet switch including 2 Gigabit Ethernet and 2 Combo 1000BASET-T/SFP ports that provides an ideal solution for workgroups and edge deployments of a network. The D-Link Single IP Management (SIM) allows administrators to cluster up a virtual stack of up to 32 dispersed switches with fewer distance limitations through a single IP address.
Flexible and cost-effective Ethernet stack
The DES-3528 stackable switch provides 24 10/100Mbps Ethernet ports and up to four Gigabit uplinks. The two combo 10/100/100BASE-T SFP slots on the front panel provide flexible copper or fiber Gigabit connection, while two 10/100/1000Base-T ports on the back panel are designed for flexible dual usage - either as stacking ports with 4Gbps bi-directional stacking bandwidth, or can simply be used as copper Gigabit uplinks. Physical Stacking capability allows users to stack up to 8 units on a scalable expansion basis, while D-Link Single IP Management (SIM) support permits users to create a virtual stack of up to 32 units. With a complete set of features and stacking capability, this switch is an attractive alternative to the more costly chassis-based switches solution. -
Comprehensive security
The DES-3528 provides users with the latest functions such as 802.1X Guest VLAN, MAC-based Access Control (MAC) and Web-based Access Control (WAC). 802.1X Guest VLAN is a comprehensive end-point security solution for user authentication/authorization and WAC guarantees granular network access control with user-friendly authentication mechanism. The switch provides IP-MAC-Port Binding to allow administrators to bind source IP to associated MAC and source port with utilization of DHCP information snooping to block illegal IP addresses keeping the network secure and audit able. With a built-in D-Link Safeguard Engine, the DES-3528 can identify and prioritize "CPU interested" packets to prevent malicious traffic from interrupting normal network flow and protect switch operation. -
Enhanced network performance and availability
The DES-3528 has a comprehensive set of features targeting enterprise and campus to provide a more flexible and expandable network. It provides Static Route Layer 2+ functionalities, 4K VLAN, advanced selective Q-in-Q, as well as delivering progressive QoS capability for mission-critical applications and multicast services. -
User-friendly and ecosystem-friendly
DES-3528 uses D-Link's Web GUI 2.0 which has an easy-to-use web interface and configuration wizards, minimizing administrators' learning curve. Utilizing the next generation of chipsets, the DES-3528 has optimized power consumption to save energy cost and contribute to the global ecosystem and a greener environment. In addition, its fanless design ensures quiet operation, ideal for deployment in open spaces.
- D-Link xStack DES-3528 - switch - 24 ports - Managed
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 + 2 x combo Gigabit SFP + 2 x 10/100/1000
- MAC Address Table Size
- 16K entries
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
- Flow control, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, WRR queuing, Broadcast Storm Control, SNTP support, DHCP snooping, ACL support, QoS, Jumbo Frames support, MLD snooping, NAP
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 21 cm x 4.4 cm
- 2.5 kg
- Enclosure Type
- Desktop 1U
- Subtype
- Fast Ethernet
- Ports
- 16K entries
- Max Units In A Stack
- 32
- Encryption Algorithm
- SSL, SSL 3.0, SSL 2.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Status Indicators
- Port transmission speed, power, link/activity
- 24 x 100Base-TX RJ-45 , 4 x 1000Base-T RJ-45 , 1 x console DB-9 management , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Redundant Power System (RPS) connector
- MTBF
- 203,785 hours
- FCC Class A certified, UL, VCCI, C-Tick, cUL, CB
- 44.1 cm
- 21 cm
- 4.4 cm
- 2.5 kg
- 0 °C
- 45 °C
- 20 - 80%
D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver | In Stock | £23.19 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
