The DAP-1160 Wireless G Access Point can be configured to operate in any of the following 7 modes: Wireless Access Point (AP); AP Client to connect to another Access Point; Bridge, with one peer AP, to easily create dedicated building-to-building links; Bridge with AP, to allow wireless clients on the bridge link; Wireless repeater, to extend the wireless coverage and cover any "dead spot"; WISP Client Router, to share an Internet connection based on Wi-Fi between wired computers without an extra router; WISP Repeater, to share an Internet connection based on Wi-Fi between wired/wireless computers without an extra router.
The AP is based on Linux, which allows the open-source community to add their own features. Robust security is included, with support for WPA/WPA2 encryption, MAC address filtering and the SSID broadcast disable function.
Enhanced connectivity
With support for IEEE 802.11g and IEEE 802.11n, along with 802.11b/g/n wireless protocols, this D-Link access point ensures a broad range of compatibility with various devices, offering users a seamless networking experience. -
Robust security
Equipped with multiple encryption algorithms including AES, TKIP, WPA, WPA-PSK, WPA2, and WPA2-PSK, the DAP-1160 provides a secure wireless connection, protecting your network from unauthorized access. -
Flexible installation
The external detachable antenna with omnidirectional directivity and a gain level of 2 dBi allows for optimal placement and enhanced signal reception and coverage. -
Easy management
Features such as IGMP snooping, MAC address filtering, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), and content filtering enable efficient network management and a user-friendly experience.
- D-Link DAP-1160 Wireless N 150 Bridge/Access Point - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11g, IEEE 802.11n, IEEE 802.11b
- Frequency Band
- 2.4 GHz
- 12 cm x 9.2 cm x 2.45 cm
- 12 cm
- 9.2 cm
- 2.45 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz
- Status Indicators
- WPS, power, wireless
- Wi-Fi Protected Setup (WPS), content filtering, MAC address filtering, Quality of Service (QoS), IGMP snooping
- Encryption Algorithm
- WPA2, WPA, WPA2-PSK, WPA-PSK, TKIP, AES
- IEEE 802.3u, IEEE 802.3, IEEE 802.11n, IEEE 802.11g
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Directivity
- Omni-directional
- Gain Level
- 2 dBi
- 2 x 100Base-TX - RJ-45
- Power Device
- External power adapter
- 0 °C
- 55 °C
- 90% (non-condensing)
