The DAP-2610 wireless access point is designed to support small-to-medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the advanced speed of Wireless AC.
- D-Link DAP-2610 - radio access point
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- Mounting brackets
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- DC 12 V
- 17 cm x 17 cm x 2.8 cm
- 314 g
- 17 cm
- 17 cm
- 2.8 cm
- 314 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.3 Gbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power
- RADIUS support, Network Access Protection (NAP), dual band
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, SSL, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft)
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 3 dBi
- 1 x 1000Base-T (PoE) - RJ-45
- Mounting brackets
- Cables Included
- 1 x network cable
- UL, IC, FCC
- PoE
- Power Device
- External power adapter
- Voltage Required
- DC 12 V
- 12 Watt
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
