The D-Link DHP-307AV kit consists of two PowerLine Homeplug AV network adapters used to distribute Ethernet over standard AC wiring within the home.
Use existing wiring to create a home network
By simply plugging one PowerLine adapter into an existing electrical socket, you can turn every power outlet into a potential network connection, making the DHP-307AV an ideal solution for sharing a high-speed Internet connection or for connecting computers, HD media players, game consoles and Network Attached Storage to your home network. It is also ideal for homes or small offices where concrete walls, successive floors in multi-storied buildings, or other architectural impediments could inhibit a wireless signal1.
200 Mbps transmission with Quality of Service (QoS)
Delivering data transfer rates of up to 200 Mbps2, D-Link's PowerLine Homeplug AV provides ample bandwidth for demanding digital home requirements, such as watching Internet TV or streaming digital music in any room. Advanced technology built into these adapters makes them more resistant to electrical interference from other household appliances, so users can fully benefit from the maximum transmission speeds. In addition to maximum throughput, D-Link's PowerLine Homeplug AV includes a built-in Quality of Service (QoS) engine that prioritises data packets in order to enhance HD video and audio streaming, online gaming and VoIP calling.
Conveniently connect
You can attach a switch or wireless Access Point (AP) to a D-Link PowerLine Homeplug AV Network Adapter, allowing you to connect multiple devices in the farthest corners of your home.
Furthermore, D-Link's Powerline Homeplug AV implements 128-bit AES encryption for securing your connection and keeping your data safe from intruders. You can set this up easily via the button on the side of the adapter.
Compatibility
Based on the industry-leading Atheros Homeplug AV technology, the adapters are compatible with other brands' devices based on the same Homeplug AV standard. However, they will not work with devices based on other standards, such as D-Link's DHP-303/343. But they will co-exist with them, so you don't need to worry about getting rid of your existing adapters.
D-Link Green™
The kit is part of D-Link Green, D-Link's program for providing eco-friendly alternatives without compromising performance: if data transmission or reception does not occur over a certain period of time, the adapter will automatically go into sleep mode to save power. This requires less than 1W, making the adapter among the first of its kind to comply with the European Union guideline on Energy-using Products (EuP), applicable since 7th January 2010.
1 Power outlets and electrical wiring must all be part of the same electrical system. Additional PowerLine Homeplug AV Ethernet adapters are required to add new devices to the network.
2 Maximum throughput based on theoretical data rate. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic and network overhead may lower actual throughput rate.
Hardware
- Homeplug AV technology by industry leader Atheros
- One 10/100 Mbps Ethernet port for connection to a router, set-top box, media player and other devices.
- Power prongs for direct plugging into a power socket
Homeplug AV performance
- 200 Mbps raw PowerLine data rate
- Built-in Quality of Service (QoS) engine to prioritise video, Internet phone (VoIP) calls and games
Configuration and management
- Easy Plug-and-Play installation
- Simple push-button security with AES data encryption
- Management via Windows-based utility program
D-Link Green
- Standby mode for power saving, EuP compliant
- Wake-on-LAN
Data transmission over electrical wiring
The D-Link DHP-307AV Powerline AV Starter Kit, compliant with the HomePlug AV standard, uses your home's existing electrical wiring to create a network or extend your existing network. It turns every power outlet into a possible network connection to access digital media devices, game consoles, print servers, computers, and network storage devices throughout your home. -
Ideal for bandwidth-intensive applications
The DHP-307AV is capable of delivering data transfer rates of up to 200 Mbps. This rapid transmission speed makes it ideal for bandwidth-intensive applications, guaranteeing smooth HD video streaming, VoIP calls, and lag-free online gaming experiences. In addition, it prioritizes Internet traffic, ensuring that multimedia applications do not experience glitches while web surfing and downloads are in progress. This device provides ample network bandwidth, enabling digital home consumers to tap into existing electrical wiring for high-quality multimedia streaming. -
Convenient setup and secure operation
The DHP-307AV plugs directly into a power outlet, and does not require any additional cables. Extend your home network by connecting multiple devices in the farthest corners of your home, or attach a switch or wireless access point to the adapter for additional connectivity. For convenient setup, an encryption key can be quickly configured with the push of a button. The adapter implements 128-bit AES data encryption to protect the network from unauthorized wire tapping. With hassle-free plug and play installation, the DHP-307AV is an ideal solution to create a wall-to-wall home network. -
Power saving feature
The DHP-307AV incorporates a power saving mode to comply with the European Energy Using Product (EuP) Directive. If no data transmission or reception occurs over a certain period of time, the adapter will automatically go into sleep mode to save power.
- D-Link PowerLine DHP-307AV - Starter Kit - powerline adapter kit - desktop
- Powerline adapter kit
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 200 Mbps
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS
- IEEE 802.3, IEEE 802.3u, HomePlug AV
- Power
- AC 120/230 V (50/60 Hz)
- 7 cm x 3.4 cm x 10 cm
- 126 g
- System Requirements
- Microsoft Windows 2000 SP4, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- 200 Mbps
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, HomePlug AV, UL, FCC Part 15 B
- Status Indicators
- Port status, power
Line Properties
- Line Coding Format
- OFDM
- 1 x HomePlug AV , 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- OS Required
- 7 cm
- 3.4 cm
- 10 cm
- 126 g
- 1-year warranty
- 0 °C
- 40 °C
- 10 - 95%
