D-Link DGS-1100 (24-Port) Gigabit Smart Switch
Quicklinx: B8G9WS00 Mfr#: DGS-1100-24P
D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
  • Gigabit Ethernet speed
    High-speed ports provide the advanced Ethernet technology while retaining backward compatibility for connections to older computers and equipment.
  • Great energy
    Efficient D-Link Green features help conserve energy without sacrificing performance so you can reduce operating costs and protect environment.
  • Smart and flexible management
    Powerful switch management functions can be performed through a web management interface or through the client-based utility.
D-Link DGS 1100-24P - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 12 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
100 W
Performance
Switching capacity: 48 Gbps , Forwarding performance: 35.71 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Remote Management Protocol
HTTP
Flow control, full duplex capability, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, LLDP support, DHCP client, Energy Efficient Ethernet, 512KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3at, IEEE 802.3az
28 cm x 23 cm x 4.4 cm
2.15 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
100 W
Performance
8K entries
Jumbo Frame Support
9216 bytes
HTTP
Flash Memory
8 MB
12 x 1000Base-T RJ-45 PoE+ - 30 W , 12 x 1000Base-T RJ-45
Internal power supply
MTBF
563,292 hours
FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
28 cm
23 cm
4.4 cm
2.15 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
B8G9 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
B8G9 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.69
