D-Link 8-Port Gigabit EasySmart Switch
Quicklinx: 9H73WS00 Mfr#: DGS-1100-08/B
With an easy to use web interface, this switch helps customers to quickly and easily deploy their networks. Its fanless design makes it completely silent and very reliable, and its eco-friendly technology saves energy and money.
  • Resilience and performance
    The basic lineup of L2 features in the EasySmart series makes them very suitable for SMB with small IT teams, without sacrificing on performance and security. Network downtime is reduced drastically with loopback detection and broadcast storm control. Security and confidentiality of network traffic is guaranteed with VLANs. Ample bandwidth on the uplinks to the rest of the network can be achieved with link aggregation, and the cable diagnostics function provides an easy and convenient way to quickly detect and troubleshoot cabling problems.
  • Versatile management
    The EasySmart series can be easily configured through an intuitive, password-protected web-based interface or a PC-based smart console utility. The web interface allows network administrators to remotely control and monitor the switch down to the port level. The SmartConsole utility is a very convenient way to set up a number of EasySmart switches in the same network segment. The SmartConsole utility will automatically discover all available switches and provide instant access, so network deployments can be completed easily and effectively.
D-Link EasySmart Switch DGS-1100-08 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC addresses: 32
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
HTTP
Flow control, Layer 2 switching, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control, D-Link Green Technology, IPv4 support, link aggregation trunking, Loopback
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
17.1 cm x 9.8 cm x 2.8 cm
420 g
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
MAC addresses: 32
8K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP
HTTP
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45
Internal power supply
MTBF
503,585 hour(s)
FCC Class A certified, C-Tick, cUL, ICES-003, RoHS, LVD, VCCI Class A
17.1 cm
9.8 cm
2.8 cm
420 g
10 - 95% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
