D-Link 12-Port Multi-Gigabit Smart Managed PoE+ Switch
Quicklinx: J7KZWS00 Mfr#: DMS-1250-12TP/B
£270.12 ex VAT
£324.14 inc VAT
The D-Link DMS 1250-12TP switch is designed to meet the demands of modern businesses, offering a blend of performance, security, and flexibility. With robust security features, including advanced encryption and authentication methods, it ensures a secure network environment. The switch's high-capacity networking capabilities, supported by a 120 Gbps switching capacity and an 89.29 Mpps packet forwarding rate, make it suitable for handling large volumes of data traffic. Versatile connectivity options, including multi-gigabit PoE+ ports and 10GBase-T/SFP+ ports, provide the flexibility needed for network expansion and integration of high-speed devices. Additionally, the switch's enhanced power management features, including a generous 240 W PoE budget, facilitate the deployment of PoE devices, reducing installation costs and complexity. With comprehensive network management tools and support for advanced protocols, the D-Link DMS 1250-12TP is an ideal solution for businesses looking to optimize their network performance and security.
  • Robust security
    With support for Extensible Authentication Protocol (EAP), RADIUS, TACACS+, and advanced encryption algorithms including MD5, PEAP, TLS 1.3, and TTLS, this switch ensures secure network access and data transmission.
  • High-capacity networking
    Equipped with a 120 Gbps switching capacity and a packet forwarding rate of 89.29 Mpps, the D-Link DMS 1250-12TP handles large data volumes efficiently, making it suitable for high-traffic networks.
  • Versatile connectivity
    Featuring 8 ports of 10/100/1G/2.5G (PoE+), 2 ports of 10GBase-T, and 2 SFP+ ports for 10GBase-X connections, this switch offers flexible options for network expansion and integration of high-speed devices.
  • Enhanced power management
    With a total PoE budget of 240 W and support for PoE+, the switch provides power and connectivity to PoE devices such as IP cameras and VoIP phones, simplifying infrastructure and reducing installation costs.
  • Comprehensive network management
    Supporting a wide range of remote management protocols including SNMP, RMON, and Telnet, alongside advanced features like VLAN support and Quality of Service (QoS), this switch offers granular control over network traffic and resource allocation.
D-Link DMS 1250-12TP - switch - 8 ports - smart
Switch - 8 ports - L2+ - smart
Subtype
2.5 Gigabit Ethernet
Ports
8 x 10/100/1000/2.5G (PoE+) + 2 x 10 Gigabit Ethernet + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 120 Gbps , Packet forwarding rate: 89.29 Mpps
MAC addresses per port: 64 , Static MAC entries: 256 , Packet buffer size: 12 Mbit , IGMP groups: 256 , MLD groups: 256 , Link aggregation groups: 8 , Link aggregation ports per channel: 8 , VLAN groups: 4094 , Queues per port: 8 , IPv4 routes (static): 128 , IPv6 routes (static): 64 , Port security entries: 64 , ARP entries: 64
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Static IP routing, STP, MSTP, RSTP, IGMP, IGMPv2, IGMPv3, MLD, MLDv2
Remote Management Protocol
IPv6, IPv4, DHCP, Telnet, TFTP, SNMP, SNMP 2c, SNMP 3, CLI, BOOTP, ICMP, RMON, MIB
6KV Surge protection, DiffServ support, QoS, port mirroring, DHCP relay, IGMP snooping, MLD snooping, 2 fans, ACL support, Flooding Storm Control, Port Security, Voice VLAN, DSCP Marking, auto-uplink (auto MDI/MDI-X), store and forward, loopback detection, LLDP support, LLDP-MED, flow control, EEE, HOL Blocking Prevention, Multicast filtering function, PD-Alive, DDM, WRR, bandwidth control, VLAN support, NDP, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, DoS attack prevention, DHCP server, IPMB, ARP inspection, ARP support, AAA, 802.1x authentication, OTP, Cable Diagnostics Function, SNMP trap, TFTP client, Telnet server, firmware upgradable, SNTP support
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3bz, IEEE 802.3an, IEEE 802.3ae, IEEE 802.3z, IEEE 802.3az, IEEE 802.3ad (LACP), IEEE 802.1D, IEEE 802.1s, IEEE 802.1w, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.3at, IEEE 802.3af
AC 100-240 V (50/60 Hz)
44 cm x 21 cm x 4.4 cm
3.24 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Ports
PoE+
PoE Budget
240 W
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Encryption Algorithm
TLS 1.3, TTLS, PEAP, MD5
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
RAM
512 MB
Flash Memory
32 MB
Status Indicators
Power, link/activity/speed, PoE max
8 x 10/100/1G/2.5G (PoE+) RJ-45 30 W , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x console RJ-45
Internal power supply
IEEE 61000-4-5, CB, UL, BSMI, VCCI Class A, FCC Class A certified, IC, RCM
United Kingdom
44 cm
21 cm
4.4 cm
3.24 kg
Limited warranty - lifetime
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: D-Link
