D-Link 8-Port Multi-Gigabit Unmanaged Switch
Quicklinx: J7LPWS00 Mfr#: DMS-108/B
£92.47 ex VAT
£110.96 inc VAT
The DMS-108 8-Port Multi-Gigabit unmanaged switch offers eight 2.5 Gigabit Ethernet for high-speed to meet your high-performance expectations. The Gigabit ports are ready for Wi-Fi 6, providing unlimited speed and performance. DMS-108 also supports IEEE 802.3az Energy-Efficient Ethernet (EEE), which can reduce power consumption and optimize usage. Without complex installation steps, plug-and-play is convenient and easy for every usage scenario.
  • Durable design
    The DMS-108 owns a metal out case with a fanless design which can improve heat dissipation and allows noise-free operation in the working area. All the high-quality designs enhance its durability and are ideally suited for Small Office Home Office (SOHO) environments.
  • Integrated networking
    The auto-sensing ports of DMS-108 flexibly build an integrated workgroup network. Through the auto-negotiation feature, these ports will detect the network speed and allow you to get the maximum speed possible for each device.
  • Traffic management
    The traffic management of DMS-108 includes IEEE 802.1p Quality of Service (QoS) and IEEE 802.3x Flow Control. The 802.1p QoS feature classified the traffic into 8 priority levels and prioritized by their importance. As for Flow Control, it will temporarily stop data transmission when the switch's input buffer is full, helping to minimize dropped packets. The traffic management features provide a more reliable connection for all your devices.
  • Green technology
    Under the concept of Eco-friendly, the DMS-108 switch features green technology, such as IEEE 802.3az Energy-Efficient Ethernet (EEE) and link status detection. While the network utilization is low, Energy-Efficient Ethernet can efficiently reduce the switch's power consumption, bringing down the cost in the inactivity duration. Also, the power-saving mode automatically powers down the ports when no link is detected. The link status detection function will effectively save energy and costs.
  • Simplified installation
    All the ports on the DMS-108 support automatic MDI/MDIX crossover without any cables. Each port connects the server, hub, router, or switch easily just by plugging in the cable. Besides, the DMS-107 ports feature LED indicators. With the indicators, you can easily distinguish link status.
D-Link DMS 108 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Ports
8 x 10/100/1000/2.5G
Performance
Switching capacity: 40 Gbps , Packet forwarding rate: 29.76 Mpps
Packet buffer size: 8.1 MB
MAC Address Table Size
4K entries
Flow control, auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, Link Fault Detection, QoS, D-Link Green Technology, fanless, metal housing, EEE
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az, IEEE 802.3bz
14.5 cm x 8.2 cm x 2.8 cm
343 g
United Kingdom
Enclosure Type
Desktop
Subtype
Ports
Performance
4K entries
Status Indicators
Power, link/activity
8 x 10/100/1000/2.5G RJ-45
External power adapter
Power Provided
12 V - 1 A
8.586 Watt
MTBF
724,033.96 hours
Plug and Play, FCC Class B certified, IC Class B, BSMI, RoHS, BSMI Class B, LVD, VCCI Class B, RCM Class B
United Kingdom
14.5 cm
8.2 cm
2.8 cm
343 g
10 - 90% RH
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% RH
Brand: D-Link
