D-Link DES 1016D - 10/100 Switch - 16 ports
Quicklinx: NJFWS00 Mfr#: DES-1016D/B
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: 100Mbps
Managed: No
POE: [N/A]
1 In Stock
£35.79 ex VAT
£42.94 inc VAT
Standard delivery Delivered within 3-5 working days
The DES-1016D 16-Port Fast Ethernet Unmanaged Desktop Switch is designed to enhance workgroup performance while providing a high level of flexibility. Powerful yet easy to use, this device allows users to simply plug any port to either a 10Mbps or 100Mbps network to multiply bandwidths, boost response time and satisfy heavy load demands.
  • Ease of use
    The DES-1016D has 16 plug-and-play ports; the switch is a perfect choice for workgroups to upgrade performance in a client/server environment. The ports can be connected to servers in full-duplex, or hubs in half-duplex.
  • Auto speed sensing
    The switch senses whether a network device is running at 10Mbps or 100Mbps and automatically adjusts for optimal performance.
  • Auto negotiation
    Whether you are running at half- or in full-duplex, the switch automatically negotiates and runs the highest supported transmission rate.
  • Auto MDI/MDIX crossover
    All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-and-Play support for 10BASE-T and 100BASE-T networks.
  • Wire-speed performance
    The DES-1016D features a non-blocking wire-speed architecture, with a 3.2Gbps switching capacity, for maximum data throughput. The DES-1016D also features an integrated universal power supply, and per port diagnostics LEDs that make it easy to "spot check" for problems. With wire-speed filtering and store-and-forward switching, the DES-1016D maximizes network performance while minimizing the propagation of bad network packets.
D-Link DES 1016D - switch - 16 ports - unmanaged - rack-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100
Performance
Switching fabric bandwidth: 3.2 Gbps
MAC Address Table Size
8K entries
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, QoS, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
28 cm x 12.58 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100
Performance
8K entries
Status Indicators
Power, link/activity
16 x 100Base-TX RJ-45
Internal power supply
FCC Class A certified, cUL, ICES-003 Class A, C-Tick Class A, LVD, VCCI Class A
28 cm
12.58 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 16
Managed: No
POE: [N/A]
Brand: D-Link
