Cisco WAVE Inline 4-Port Adapter
Quicklinx: 62FNWS00 Mfr#: WAVE-INLN-4CG=
The WAE appliance supports one optional 4-port Ethernet inline network adapter. The inline network adapter is a full-height, three-quarter-length PCI-X network interface card that contains four independent Gigabit Ethernet ports.
The Cisco WAE inline network adapter provides an inline traffic interception capability for your appliance. When you configure the WAE appliance for inline interception mode, you can set attributes to control which interfaces are to be used over which VLANs. By default, the adapter operates on all inline-capable interfaces and VLANs. You can configure the inline redirection feature using the WAAS 4.0.7 CLI or the WAAS 4.0.7 Central Manager GUI.
Cisco Inline Network Adapter - network adapter - PCIe x4 - Gigabit Ethernet x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
Ports
16.8 cm x 11.1 cm
180 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
P/N: WAVE-574-K9, WAVE-574-K9=, WAVE-574-K9-RF
Network adapter
Plug-in card
PCI Express x4
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Full duplex capability, auto-negotiation
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x4
16.8 cm
11.1 cm
180 g
50 °C
0 - 90%
