Cisco Small Business Pro 8-port 10/100 PoE Switch
Quicklinx: 6ZRGWS00 Mfr#: ESW-520-8P-K9
The Cisco ESW 500 series is a group of managed Ethernet switches that provide wire-speed Fast Ethernet and Gigabit Ethernet connectivity, integrated security, quality of service (QoS), and Power over Ethernet (PoE) to support all of your business network needs. With the Cisco ESW 500 series, you can take advantage of a proven network solution and a broad portfolio of high-performance, easy-to-manage switches that are designed and priced for small businesses.
The Cisco ESW 500 series switches provide security, management, and other capabilities far beyond what unmanaged or "smart" switches can provide, without requiring you to configure features you don't need.
  • Move beyond your traditional phone system
    The Cisco smart business communications system lets you transform your business by bringing together all of your communications onto a single network. The Cisco ESW 500 series works hand in hand with other Cisco smart business communications system products, such as the Cisco unified communications 500 series for small business. Together, the solution lets you support all of your company's phone calls, messaging, and data. Your employees can be more productive, and you can save money by managing and paying for just one network.
  • Securely extend network access with wireless
    The Cisco ESW 500 series switches with PoE can connect and power your wireless access points while supporting robust security and identity services to protect your wireless environment. By choosing Cisco ESW 500 series switches with both PoE and Gigabit Ethernet connectivity, you can support wireless technologies such as 802.11n and extend the life of your wireless technology investment.
  • Connect your small business
    The Cisco ESW 500 series switches meet the needs of a range of small businesses. The 10/100 Fast Ethernet switches can provide outstanding desktop connectivity in small networks to connect computers, printers, and servers. They are well suited to businesses starting up or businesses that previously used basic, unmanaged switches but now require support for additional features such as QoS traffic prioritization and advanced security. The Gigabit Ethernet switches in the Cisco ESW 500 series can go even further, helping you achieve optimal performance from your desktop PCs, servers, and other shared devices with Fast or Gigabit Ethernet connectivity.
  • Outstanding performance
    The Cisco ESW 500 Series supports up to Gigabit Ethernet speeds to deliver optimal network performance, enabling you to add high-bandwidth data, voice, video, and wireless applications. Ultimately, the switches give you the ability to meet more rigorous application demands and help ensure that your employees always have access to the tools they need to be responsive to your customers and each other.
  • High reliability
    Cisco ESW 500 series switches have been developed and rigorously tested to provide reliable connectivity and performance, especially when supporting advanced voice, video, and wireless services. These features help you keep your network available, prevent costly downtime, and keep your employees and customers connected to the applications they need.
  • Power over Ethernet
    Cisco ESW 500 Series Switches are available with up to 48 PoE ports of Fast Ethernet and 24 PoE ports of Gigabit Ethernet connectivity. PoE allows you to power network-attached devices such as IP phones, video cameras, and wireless access points directly over the Ethernet connection, without an external power supply. The result is a simpler and less expensive deployment, without the need to install a separate power supply for each connected endpoint.
  • Quality of service
    Cisco ESW 500 Series Switches feature QoS intelligence to prioritize delay-sensitive and high-bandwidth network traffic, enhancing network performance and allowing businesses to support demanding services such as real-time voice and video.
  • Simple configuration and management
    Cisco ESW 500 series switches are designed to be configured and managed by small businesses or the Cisco partners that serve them. Whether you are installing a single switch or an advanced voice and video communications system, simple graphical user interfaces (GUIs) help your staff easily configure, manage, and troubleshoot your network.
Cisco Small Business Pro ESW-520-8P - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 1 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 3.6 Gbps , Forwarding performance (64-byte packet size): 2.7 Mpps
MAC Address Table Size
8000 entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, Layer 2 switching, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, TFTP support, ACL support, QoS, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
22 cm x 17 cm x 4.4 cm
1.05 kg
5-year warranty
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE
Performance
8000 entries
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, power, PoE, link/activity
8 x 10Base-T/100Base-TX - RJ-45 PoE , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x console DB-9 , 1 x SFP (mini-GBIC)
External power adapter
80 Watt
1 x serial cable
Mounting Kit
Included
MTBF
393,993 hours
C-Tick, UL 60950, CSA C22.2, FCC CFR47 Part 15
22 cm
17 cm
4.4 cm
1.05 kg
Limited warranty - replacement - 5 years - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 90 days
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
