Cisco CATALYST 4500 E-SERIES
Quicklinx: 75QSWS00 Mfr#: WS-X45-SUP7-E=
Establishing borderless leadership is now easier than ever to achieve with the Cisco Supervisor Engine 7-E, an enterprise-class borderless network access and aggregation supervisor engine. Cisco Supervisor Engine 7-E is built with price-performance aggregation deployments in mind, providing increased Gigabit Ethernet and 10 Gigabit Ethernet fiber density along with hardware capabilities to support enterprise-class aggregation functionalities. Supervisor Engine 7-E facilitates borderless user experiences for enterprise, public sector, mid-market, and commercial customer deployment business-critical applications.
  • Predictable performance and scalability
    The Supervisor Engine 7-E is also optimized for multimedia applications with its advanced multicast support offered by features such as Protocol Independent Multicast (PIM), Source-Specific Multicast (SSM), and Pragmatic General Multicast (PGM), giving your network additional scalability to support multimedia applications.
  • Simplified operations through automation
    As campus switching has grown to support increasing enterprise demands, so has the need to deploy and manage evolving technologies. Simplified operations are critical in meeting these challenges and achieving increased operational efficiency through proactive management and reduction in unplanned network downtime.
  • Optimized application visibility with flexible NetFlow
    Cisco IOS flexible NetFlow allows optimization of the network infrastructure, reducing operation costs, improving capacity planning and security incident detection with increased flexibility and scalability. The Cisco Supervisor Engine 7-E enables powerful, on-box and customizable event correlation and policy actions. This allows the switches to trigger customized event alarms or policy actions when the predefined condition is met. With no external appliance required, customers are able to use existing infrastructure to perform traffic monitoring, making traffic analysis economical even on large IP network.
  • IPv6 support
    IPv6 is important for the future of IP networking and is critical for the expansion of IP address space in the future. IPv6 capability is required by many companies and is being mandated by governments worldwide. The Supervisor Engine 7-E supports Multicast Listener Discovery (MLD) snooping for IPv6, enhancing performance and reducing network traffic by allowing a switch to dynamically add and remove hosts from a multicast group.
Cisco Supervisor Engine 7-E - control processor
Control processor
Plug-in module
1.5 GHz
RAM
2 GB (installed) / 4 GB (max)
Performance
Switching capacity: 848 Gbps , Per-slot switching capacity: 48 Gbps , IPv6 routing: 125 Mbps , IPv4 routing: 250 Mbps
QoS hardware entries: 128000 , Security services entries: 128000 , Virtual interfaces (VLANs): 4096 , Multicast entries (IPv4): 70000 , Multicast entries (IPv6): 64000 , Multicast entries (shared between IPv4 and IPv6): 16000 , MAC addresses: 55000 , IPv6 routes: 128000 , IPv4 routes: 256000 , Spanning Tree Protocol instances: 3000 , Switched virtual interfaces (SVIs): 4096 , NetFlow entries: 128000
Control processor
Processor / Memory / Storage
Processors Installed
1.5 GHz
RAM
2 GB (4 GB max) SDRAM
Plug-in module
Wired
Routing Protocol
PIM-SM, PIM-DM, PIM-SSM
Performance
Uplink, IPv6 support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping
Communications
Supported Flash Memory Cards
SD Memory Card
Expansion Slots
4 (total) / 4 (free) x SFP+
1 x management - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x USB - Type A
Compatible Slots
1 x Expansion Slot
NEBS level 3, CISPR 22 Class A, EN 61000-3-2, EN55022, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, CSA 22.2 No. 60950, EN 61000-6-1, AS/NZ 3548 Class B, AS/NZS 3260, ICES-003 Class A, FCC Part 15 A, EN 55022 Class A
Limited warranty - lifetime
10 - 90% (non-condensing)
75QS C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
75QS C2G 12m USB 2.0 A/A Active Extension Cable In Stock £18.89
