Cisco ASA 5516-X with FirePOWER 8 ports GigE 1U Rack-Mountable
Quicklinx: C74XWS00 Mfr#: ASA5516-FPWR-K9
Meet the industry's first adaptive, threat-focused next-generation firewall (NGFW) designed for a new era of threat and advanced malware protection. Cisco ASA with FirePOWER Services delivers integrated threat defense for the entire attack continuum - before, during, and after an attack. How? By combining the proven security capabilities of the Cisco ASA firewall with the industry-leading Sourcefire threat and Advanced Malware Protection (AMP) features together in a single device. The solution uniquely extends the capabilities of the Cisco ASA 5500-X Series Next-Generation Firewalls beyond what today's NGFW solutions are capable of. Whether you need protection for a small or midsized business, a distributed enterprise, or a single data center, Cisco ASA with FirePOWER Services provides the needed scale and context in a NGFW solution.
  • Superior multilayered protection
    Cisco ASA with FirePOWER Services brings distinctive threat-focused next-generation security services to the Cisco ASA 5500-X Series Next-Generation Firewalls and Cisco ASA 5585-X Adaptive Security Appliance firewall products. It provides comprehensive protection from known and advanced threats, including protection against targeted and persistent malware attacks. Cisco ASA is the world's most widely deployed, enterprise-class stateful firewall.
  • Unprecedented network visibility
    Cisco ASA with FirePOWER Services is centrally managed by the Cisco FireSIGHT Management Center, which provides security teams with comprehensive visibility into and control over activity within the network. Such visibility includes users, devices, communication between virtual machines, vulnerabilities, threats, client-side applications, files, and web sites. Holistic, actionable indications of compromise (IoCs) correlate detailed network and endpoint event information and provide further visibility into malware infections. Cisco's enterprise-class management tools help administrators reduce complexity with unmatched visibility and control across NGFW deployments. Cisco FireSIGHT Management Center also provides content awareness with malware file trajectory that aids infection scoping and root cause determination to speed time to remediation.
  • Reduced costs and complexity
    Cisco ASA with FirePOWER Services incorporates an integrated approach to threat defense, reducing capital and operating costs and administrative complexity. It smoothly integrates with the existing IT environment, work stream, and network fabric. The appliance family is highly scalable, performs at up to multigigabit speeds, and provides consistent and robust security across branch, Internet edge, and data centers in both physical and virtual environments. With Cisco FireSIGHT Management Center, administrators can streamline operations to correlate threats, assess their impact, automatically tune security policy, and easily attribute user identities to security events. Cisco FireSIGHT Management Center continually monitors how the network is changing over time. New threats are automatically assessed to determine which ones can affect your business. Responses are then focused on remediation and network defenses are adapted to changing threat conditions. Critical security activities such as policy tuning are automated, saving time and effort, while protections and countermeasures are maintained in an optimal state.
Cisco ASA 5516-X with FirePOWER Services - security appliance
Security appliance
Rack-mountable - 1U
RAM
8 GB
Flash Memory
8 GB
Hard Drive
100 GB x 1
Ports Qty
8
Gigabit Ethernet
Performance
Inspection throughput: 1.8 Gbps , Multiprotocol firewall throughput: 900 Mbps , Connection rate: 15000 connections per second , Application control (AVC) throughput: 250 Mbps , Application control (AVC) and IPS throughput: 125 Mbps , VPN throughput (3DES/AES): 250 Mbps , Application control (AVC) or IPS sizing throughput: 150 Mbps
Concurrent sessions: 250000 , Cisco AnyConnect Premium/Apex VPN peers: 250 , IPSec VPN peers: 300 , Virtual interfaces (VLANs): 100
43.688 cm x 28.672 cm x 4.369 cm
3 kg
90 days warranty
Security appliance
Height (Rack Units)
1U
43.688 cm
28.672 cm
4.369 cm
3 kg
Processor / Memory / Storage
RAM
8 GB
Flash Memory
8 GB
Hard Drive
SSD 100 GB x 1 - mSATA
Rack-mountable
Ports Qty
8
Wired
Gigabit Ethernet
Performance
Firewall protection, VPN support, VLAN support
Encryption Algorithm
Triple DES, AES
1 x 1000Base-T (management) - RJ-45 , 1 x USB 2.0 - Type A , 1 x mini-USB , 1 x console - RJ-45 , 8 x 1000Base-T - RJ-45
CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 60950, EN 61000-3-3, EN55024, UL 60950, VCCI V-3, AS/NZS 60950, CAN/CSA C22.2 No. 60950, CNS 13438, EN 301 489-7, EN 301 489.4, EN 301 489-1, EN 301 489-17, EN 300386, EN 301 489-24
External power adapter
Limited warranty - advance parts replacement - 90 days - response time: 10 days
10 - 90% (non-condensing)
