Cisco CATALYST 3K-X 1G NETWORK MODUL
Quicklinx: 76BLWS00 Mfr#: C3KX-NM-1G=
The module has four 1-Gigabit SFP module slots. Any combination of standard SFP modules is supported.
  • Enhanced connectivity
    Equipped with four SFP expansion slots, this module allows for a significant increase in network flexibility and scalability. By supporting Gigabit Ethernet, it ensures high-speed data transfers and efficient network operations.
  • Reliable performance
    Designed for continuous operation, the module boasts an impressive Mean Time Between Failures (MTBF) of over 5 million hours, highlighting its reliability and durability in demanding environments.
  • Seamless integration
    With its Plug-and-Play form factor, the module integrates smoothly into existing setups, ensuring an easy upgrade path without the need for extensive modifications. Compatibility with PC systems further enhances its versatility.
Cisco - expansion module - 4 ports
Expansion module
Plug-in module
Ports Qty
4 ports
1GbE
Catalyst 3560X-24, 3560X-48, 3750X-12, 3750X-24, 3750X-48
Expansion module - 4 ports
Plug-in module
Wired
Gigabit Ethernet
Status Indicators
Link/activity
Expansion Slots
4 (total) / 4 (free) x SFP
Compatible Slots
1 x Expansion Slot
MTBF
5,083,574 hours
Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750X-12S-E, 3750X-12S-S, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-L, 3750X-24T-S, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-L, 3750X-48T-S
