Cisco 802.11g LWAPP Access Point With Internal Antennas
Quicklinx: 5DX0WS00 Mfr#: AIRLAP1131AGEK9
  • Wi-Fi CERTIFIED
The Cisco Aironet 1130AG Series IEEE 802.11a/b/g Access Point is a fixed-configuration, dual-band access point. Built in to the access point are two radios each with diversity antennas that provide omni-directional coverage.
The Cisco Aironet 1130AG supports local power as well as Power over Ethernet (PoE), either by an IEEE 802.3af-compliant Power Sourcing Equipment (PSE) device, such as a switch, or by a device capable of providing 12.95W to a Powered Device (PD) and compliant with Cisco Inline Power. The Cisco Aironet 1130AG Series includes a console port for management.
Cisco Aironet 1130AG - radio access point - Wi-Fi
Radio access point
External
Europe
RAM
32 MB
Flash Memory
16 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Power Over Ethernet (PoE) Supported
PoE
19.1 cm x 3.3 cm x 19.1 cm
0.7 kg
1-year warranty
Radio access point
19.1 cm
3.3 cm
19.1 cm
0.7 kg
Europe
Processor / Memory / Storage
RAM
32 MB
Flash Memory
16 MB
External
Wireless
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, OFDM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
SNMP, Telnet, HTTPS
Max Range Indoors
137 m
Max Range Open Space
290 m
Status Indicators
Active, error, status
Auto-sensing per device, BOOTP support
Encryption Algorithm
LEAP, AES, 128-bit WEP, 40-bit WEP, TLS, PEAP, TKIP, WPA, WPA2
Authentication Method
Secure Shell (SSH), MS-CHAP
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
1 x 100Base-TX (PoE) - RJ-45
ETSI
PoE
External power adapter
12.2 Watt
Limited warranty - 1 year
