Cisco 4G LTE Wireless WAN Card Wireless Cellular modem
Quicklinx: DF74WS00 Mfr#: EHWIC-4G-LTE-GB=
The Cisco 4G LTE WWAN EHWIC is the first enterprise-class 4G multimode LTE WWAN solution. With 4G LTE, WWAN is a primary WAN link solution. Businesses can now run applications such as interactive video and telepresence on a primary 4G LTE WWAN link, which is 10 to 15 times faster and has 5 times lower latency than 3G links.
Cisco 4G multimode LTE WWAN EHWICs provides persistent, reliable LTE connectivity with fallback and transparent handoff to earlier technologies. The card provides bandwidth to support high-definition (HD) and peer-to-peer (P2P) video calls, providing customers with an excellent mobile broadband experience.
  • Integrated 4G LTE WWAN broadband
    With the 4G LTE WWAN modem integrated into the router, you gain the benefits of simplified installation and management. In addition, the Cisco 4G LTE WWAN EHWIC is tightly integrated with Cisco ISRs, which run the industry-leading Cisco IOS software, giving access to all the advanced features of Cisco IOS software such as quality of service (QoS), intelligent network queuing, and robust security.
  • Performance
    With increasing data use and the proliferation of web-based applications at remote sites, there is an increasing need for high-speed (broadband) data connections to run mission-critical applications at these sites. 4G LTE WWAN services promise low-latency links at high speeds.
  • Short installation time
    Businesses sometimes have to wait weeks or months to get data circuits installed at locations. For temporary or seasonal sites, wireless data services allow instant connectivity anywhere there is cellular coverage, and rapid deployment allows you to quickly set up networks with WAN connectivity.
  • Network resiliency through WAN diversity
    WAN connectivity is crucial to the functioning of your business, and any downtime means a loss of productivity and lost opportunity. Staying connected and operational during a network outage can be vital. A wireless connection for backup to a remote site provides protection against line outages and an additional level of redundancy because the 4G LTE WWAN infrastructure is often served by separate facilities, providing redundancy for the entire local loop.
  • Hardware-ready 4G LTE multiple bearer QoS
    Future alignment with 4G LTE multiple-bearer QoS is supported. The QoS feature is service provider specific, and its support aligns with the service provider's roadmap.
Cisco 4G LTE Wireless WAN Card - wireless cellular modem - 4G LTE
Wireless cellular modem - EHWIC
Internal
Max Transfer Rate
100 Mbps
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
7.8 cm x 12.4 cm x 1.9 cm
147 g
90 days warranty
ISR G2
Internal
Built-in Devices
GPS
Modem
Bus
EHWIC
Wireless
Max Transfer Rate
100 Mbps
2 x aerial - TNC , 1 x aerial - SMA , 1 x mini-USB
SIM Card Supported
Regular (mini-SIM) x 1
CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, AS/NZS 60950-1, RSS-102, FCC Part 15, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, RSS-132, RSS-129, RSS-133, FCC Part 22, FCC Part 24, VCCI V-3, AS/NZS CISPR 22, CNS 13438, EN 50385, EN 301 489-7, EN 301 489-1, EN 300 386, CAN/CSA-C22.2 No. 60950-1, EN 301 489-24, EN 301 511
Limited warranty - 90 days
7.8 cm
12.4 cm
1.9 cm
147 g
Cisco ISR G2
