Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switch provides a powerful foundation to support your business network.
High performance and reliability
Get the high availability and performance you need to support vital business applications while reducing downtime. -
Advanced features
Control network traffic comes with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support. -
Easy setup and management
Intuitive browser-based tools, mass deployment capabilities, and consistent features across all models simplify setup and configuration. -
An eco-friendly solution
Switches optimize power usage for energy efficiency without compromising performance.
- Cisco Small Business SG300-28 - switch - 26 ports - Managed
- Switch - 26 ports - L3 - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 26 x 10/100/1000 + 2 x combo Gigabit SFP
- MAC Address Table Size
- 8K entries
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.5 cm
- 3.3 kg
- Localisation
- Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8K entries
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 16 MB Flash
- Status Indicators
- Port transmission speed, system, link/activity
- 28 x 1000Base-T RJ-45 , 1 x console DB-9 management , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- MTBF
- 179,141 hours
- UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
- Localisation
- 44 cm
- 25.7 cm
- 4.5 cm
- 3.3 kg
- Limited warranty - replacement - lifetime - response time: next business day
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.65 |
