Cisco 1 PORT PACKET/SONET OC3C/STM1
Quicklinx: 7DKRWS00 Mfr#: pa-pos-1oc3=
The PA-POS-1OC3 provides a single Packet-over-SONET (POS) port in a single port adapter slot. The port functions as a single independent OC-3c/STM1 port. The PA-POS-1OC3 is used as a direct connection between the supported router or switch platform and an external network.
Cisco - expansion module
Expansion module
Plug-in module
16.5 cm x 12.7 cm x 2.5 cm
0.4 kg
Cabling Type
Fibre optic
HDLC, Frame Relay, SONET/SDH, PPP
Data Transfer Rate
155.52 Mbps
Line Rate
OC-3c/STM-1
Cisco 7204 VXR
Expansion module
Plug-in module
Wired
Cabling Type
Fibre optic
Data Transfer Rate
155.52 Mbps
Remote Management Protocol
SNMP
Line Rate
OC-3c/STM-1
Status Indicators
Status, alarm, receive
Full duplex capability, PoSONET
Expansion Slots
1 (total) / 1 (free) x SFP
Compatible Slots
1 x Expansion Slot
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, CSA 22.2 No. 60950, EN 61000-6-1, AS/NZS 3260, AS/NZ 3548 Class A, FCC Part 15, ICES-003 Class A
16.5 cm
12.7 cm
2.5 cm
0.4 kg
45 °C
5 - 85%
Cisco 7204 VXR
