Chief Professional Mounting Flat Panel Single Stand
Quicklinx: 77W8WS00 Mfr#: MF1UB
Type: Stand
Hurry, only 1 left in stock!
£292.94 ex VAT
£351.52 inc VAT
The all MF1-U Flat Panel Display Floor Stand features a lightweight, collapsible design to meet a wide range of applications. Innovative new features include a telescoping height-adjustment mechanism, integrated cable management, and a modular design that allows for fast disassembly.
  • Adjustable comfort
    Equipped with Centris Technology, this stand allows for smooth pitch adjustments, ensuring the perfect viewing angle for any audience or room configuration.
  • Versatile design
    With an adjustable height feature, this stand caters to various display needs, making it ideal for presentations, information display, or entertainment setups.
  • Durable construction
    Crafted from high-quality aluminum, this stand is designed to support flat panels weighing up to 46.7 kg, offering a reliable solution for your display requirements.
Chief Medium Flat Panel AV Floor Stand Display Mount - For Displays 32-65" - Black stand - for flat panel - black
Stand
76.4 cm x 78.4 cm
Adjustable Height
121.9-213.4 cm
Adjustments
Pitch
Recommended Use
Flat panel
Max Load Weight
46.7 kg
Material
Aluminium
10 years warranty
76.4 cm
78.4 cm
Adjustable Height
121.9-213.4 cm
Material
Aluminium
AV Furniture
Stand
Recommended Use
Flat panel
Adjustments
Pitch
Max Load Weight
46.7 kg
Adjustable height, Centris Technology
Limited warranty - 10 years
Type: Stand
Brand: Chief Professional Mounting
