C2G TruLink 2-Port UXGA+3.5mm Monitor Splitter
Quicklinx: 7BD6WS00 Mfr#: 89033
The Trulink 2-port monitor splitter is an excellent solution for distributing video across two displays. Create a simple digital signage application or use in a conference room or classroom to broadcast computer content to multiple displays. With integrated video signal enhancement, displays can be placed up to 64 meters from the source without sacrificing video quality. This provides complete flexibility while ensuring the highest quality resolution. Multiple splitters can be added to expand the number of displays and distance.
C2G TruLink 2-Port UXGA + 3.5mm Monitor Splitter - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
USB powered
4.5 cm x 6.7 cm x 2.2 cm
1-year warranty
Enclosure Type
Desktop
Max Resolution
1600 x 1200
Max Video Bandwidth
300 MHz
USB powered, signal enhancement function
2 x VGA output HD-15 , 2 x audio output mini-jack , 1 x VGA input HD-15 , 1 x audio input mini-jack
1 x USB power cable
RoHS
4.5 cm
6.7 cm
2.2 cm
Limited warranty - 1 year
