C2G USB 3.1 USB C to VGA Adapter - White
Quicklinx: CHQHWS00 Mfr#: 88844
Colours:
£22.13 ex VAT
£26.55 inc VAT
This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Seamless compatibility
    Designed to bridge the gap between new and old technologies, the C2G USB 3.1 USB Type-C to VGA Adapter ensures seamless compatibility with PC systems. This feature allows users to connect their modern USB-C devices to VGA display monitors effortlessly, making it an ideal solution for presentations, conferences, and educational purposes.
  • High-quality video output
    With support for maximum external resolutions up to 1920 x 1200, this external video adapter delivers crisp, clear, and vibrant visuals. The adapter's ability to transmit high-quality VGA signals makes it perfect for video streaming, gaming, and professional applications where image clarity is important.
  • Plug-and-Play convenience
    Adhering to Plug-and-Play compliant standards, the adapter offers a hassle-free setup without the need for additional drivers or software. This feature ensures a straightforward connection process, allowing users to enjoy an uninterrupted display experience.
C2G USB 3.1 USB Type C To VGA Adapter - USB C to VGA White - external video adapter - white
External video adapter
Bus Type
USB 3.1
Max Resolution
1920 x 1200
Interfaces Details
VGA , USB 3.1 (USB-C)
Enclosure Colour
White
3-year warranty
Bus Type
USB 3.1
Max Resolution
1920 x 1200
Interfaces Details
Plug and Play
32 g
Enclosure Colour
White
Limited warranty - 3 years
50 °C
Brand: C2G
