C2G 6in USB-C® Female to USB-A Male SuperSpeed USB 5Gbps Adaptor
Quicklinx: GPPMWS00 Mfr#: 54428
£11.36 ex VAT
£13.63 inc VAT
This USB-C Female to USB-A Male SuperSpeed USB 5Gbps Adapter Converter is the perfect solution for connecting a USB-C device to a laptop or desktop computer that does not have a USB-C port.
Simply connect the adapter converter into a USB-A port of a laptop or desktop computer and enjoy plug and play connectivity for USB-C devices. This adapter converter supports a data rate up to 5Gbps for data transfer and 900mA of power for device operation and charging. This adapter converter is compatible with earlier USB versions.
The USB-C connector has a symmetrical design which is identical on both sides, so no more worrying about whether it's upside-down or right-side-up. It will plug in the first time, every time - while preventing damage to the connector port from frequent plugging and unplugging.
  • Effortless connectivity
    The USB-C to USB-A Adapter bridges the gap between USB-C and USB-A devices, offering a seamless connection that enhances productivity and ease of use. With its reversible USB-C design, plugging in is hassle-free, eliminating the common frustration of connector orientation.
  • High-speed data transfer
    Experience rapid data transfer speeds of up to 5 Gbps with USB 3.0 technology. This adapter ensures quick and efficient file transfers, making it ideal for devices and tasks requiring high bandwidth.
  • Durable design
    Constructed with a PVC jacket and molded strain relief, this adapter is built for durability and long-term use. Its robust design protects against wear and tear, ensuring reliable performance.
C2G USB C to USB Adapter - SuperSpeed USB Adapter - 5Gbps - F/M - USB-C adapter - 24 pin USB-C to USB Type A - 15.2 cm
USB-C adapter
Molded
Length
15.2 cm
Connector
24 pin USB-C - female - reversible
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB-C adapter
Jacket Material
PVC
Molded
Length
15.2 cm
17.7 g
Connector
USB 3.0, Plug and Play
Brand: C2G
