C2G DisplayPort to HDMI, VGA, or DVI Adapter Converter - Vid
Quicklinx: D0DSWS00 Mfr#: 80928
£26.09 ex VAT
£31.30 inc VAT
Send a video signal from a tablet, laptop computer, or another source device with a DisplayPort output port to a projector, monitor, or HDTV with an HDMI, DVI or VGA input port. This compact all-in-one converter is an ideal solution for use in schools, conference rooms, or other work spaces that may utilize assorted displays with varying inputs in multiple rooms throughout a building. On The Go Enhanced.
Be prepared for any meeting, presentation, or event with the full confidence that you have the right connections in an ultra-compact design. The DisplayPort to HDMI, VGA, or DVI adapter allows you to connect a DisplayPort-equipped laptop or tablet to a projector, monitor, or HDTV with an HDMI, VGA, or DVI input port. The compact design of this adapter converter makes it a perfect fit for BYOD (Bring Your Own Device) applications in education or corporate environments. Straightforward Install.
This simple plug and play adapter converter does not require drivers for install and the device is powered through DisplayPort bus power, so no additional power adapters are needed. Port Protection.
The dongle-style adapter converter reduces strain on the video port. The cable between the DisplayPort connection and the adapter converter provides strain relief that protects the port from strain damage as cords are moved.
  • Colour
  • Warranty
    3 years
  • Input
    (1) DisplayPort Male
  • Output
    (1) HDMI Female, (1) VGA Female, (1) DVI Female
C2G DisplayPort to HDMI, VGA, or DVI Adapter Converter - video converter - black
Video converter
Max Resolution
3840 x 2160
Max Resolution Details
DVI (Dual-Link): 1920 x 1080 at 60 Hz / HDMI: 3840 x 2160 at 30 Hz / VGA: 1920 x 1080 at 60 Hz
1 x DisplayPort input - 20 pin DisplayPort , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x DVI-I (dual link) - 24+5 pin combined DVI
Enclosure Colour
3-year warranty
Video converter
Max Resolution
3840 x 2160
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x DVI-I (dual link) - 24+5 pin combined DVI - female
Gold plated connectors
66.2 g
Enclosure Colour
Limited warranty - 3 years
Brand: C2G
