C2G HP J9151A-C2G SMF Transceiver
Quicklinx: CJ00WS00 Mfr#: 89093
This SFP+ Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number J9151A. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
  • Colour
    Silver
  • Connector 1
    SFP Male+
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
10 km
HP J9151A
1.27 cm x 5.59 cm x 0.76 cm
68 g
HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-LR - LC single-mode female x 2
MSA
HP J9151A
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl , HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
