C2G NETGEAR AGM731F-C2G MMF Transceiver
Quicklinx: CJ03WS00 Mfr#: 89095
This SFP (mini-GBIC) Transceiver Module is designed for use with Netgear network equipment and is equivalent to Netgear part number AGM731F. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Netgear and the Netgear logo are trademarks or registered trademarks of Netgear. This product is not certified or endorsed by Netgear.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
Netgear AGM731F
1.27 cm x 5.59 cm x 0.76 cm
68 g
NETGEAR M4300-28G-PoE+
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MSA
Netgear AGM731F
1.27 cm
5.59 cm
0.76 cm
68 g
Limited warranty - lifetime
