C2G Snap-In HDMI® F/F Keystone Insert Module - White
Quicklinx: 8GZ1WS00 Mfr#: 81302
Type: Modules
£11.78 ex VAT
£14.13 inc VAT
This Snap-In HDMI Keystone Insert Module allows you to custom-configure your keystone wall plates and patch panels for greater control and more flexibility and provides a full range of solutions for voice, home networking, home office, audio/video and more. Use this coupler for HDMI applications; just snap it into patch panels, compatible wall plates and surface boxes for a straightforward installation.
  • Effortless integration
    Designed for seamless integration into any home or office setup, this Snap-In HDMI Keystone Insert Module from C2G allows for a clean and professional installation. Its keystone type design fits perfectly into existing wall plates, making it an ideal solution for expanding your HDMI connectivity without the clutter.
  • High compatibility
    With its compatibility with PC systems and support for 19-pin HDMI Type-A connectors, this modular insert ensures a reliable connection between a wide range of devices. Whether it's connecting a computer to a projector or a gaming console to a TV, this insert provides the flexibility you need.
  • Simplified connectivity
    Featuring a single port design, this HDMI Keystone Insert Module simplifies your cabling needs, providing a straightforward solution for HDMI access. The female connector type ensures easy and secure cable attachment, enhancing your multimedia experience without the hassle.
C2G Snap-In HDMI Keystone Insert Module - modular insert
Modular insert - HDMI
White
Port Qty
1 port
Modular insert
Enclosure Colour
White
Cabling & Wiring
Port Qty
1 port
Keystone type
Connector Provided
1 x 19 pin HDMI Type A female
Type: Modules
Brand: C2G
