The RJ45 cap is perfect for protecting any unused Ethernet port from dust and debris when it is not in use. The RJ45 cap is constructed of high quality ABS plastic and is designed for durability and a long life.
Durable design
Crafted from ABS plastic, this dust cap offers a robust solution for protecting RJ45 connectors against dust, debris, and physical damage, ensuring a longer lifespan for your network connections. -
Easy cable management
Specially designed for cable management and cabling accessories, these dust caps help maintain an organized and efficient networking environment by preventing dust accumulation that can lead to connectivity issues.
- C2G 10 Pack RJ45 Dust Cap - dust cover
- Product Type
- Dust cover
- Packaged Quantity
- 10 (specifications are for single item)
- 25 g
- Product Material
- ABS plastic
- Black
- Limited lifetime warranty
- Packaged Quantity
- Product Type
- Dust cover
- Product Material
- ABS plastic
- 25 g
- Enclosure Colour
- Black
- Limited warranty - lifetime
