C2G Cisco SFP-GE-L Compatible SFP (mini-GBIC) Transceiver Module
Quicklinx: C5TCWS00 Mfr#: 88602
This Cisco SFP-GE-L compatible SFP transceiver provides 1000Base-LX throughput up to 10km over single-mode fibre (SMF) at a wavelength of 1310nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    SFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G Cisco SFP-GE-L Compatible 1000BASE-LX SMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
Cisco SFP-GE-L
1.27 cm x 5.59 cm x 0.76 cm
31 g
Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MSA
Cisco SFP-GE-L
1.27 cm
5.59 cm
0.76 cm
31 g
Limited warranty - lifetime
