This Cisco GLC-FE-100FX-RGD compatible SFP transceiver provides 100Base-FX throughput up to 2km over multi-mode fibre (MMF) at a wavelength of 1310nm using a LC connector. It is also capable of withstanding rugged environments and can operate at temperatures between -40[D]C to +85[D]C. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
- C2G Cisco GLC-FE-100FX-RGD Compatible 100BASE-FX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - 100Mb LAN
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-FX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 2 km
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-FE-100FX-RGD
- 1.27 cm x 5.59 cm x 0.76 cm
- 30 g
- Limited lifetime warranty
- Designed For
- P/N: A900-IMA8S1Z, IE-2000U-4S-G, IE-4000-16GT4G-E, IE-4000-16T4G-E, IE-4000-4GS8GP4G-E, IE-4000-4S8P4G-E, IE-4000-4TC4G-E, IE-4000-8GS4G-E, IE-4000-8GT4G-E, IE-4000-8GT8GP4G-E, IE-4000-8S4G-E, IE-4010-16S12P, IE-4010-4S24P, IE-5000-16S12P, IR1821-K9, IR1831-K9, IR1833-K9, IR1835-K9
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-FX
- 100Mb LAN
- 100 Mbps
- 1310 nm
- 2 km
- 1 x Ethernet 100Base-FX - LC multi-mode female x 2
- MSA
- 1.27 cm
- 5.59 cm
- 0.76 cm
- 30 g
- Limited warranty - lifetime
- -40 °C
- 85 °C
- Designed For
- P/N: A900-IMA8S, A900-IMA8S=, A900-IMA8S1Z, A900-IMA8T, A901-4C-F-D, A901-4C-FT-D, A901-6CZ-F-A, A901-6CZ-F-A-RF, A901-6CZ-F-D, A901-6CZ-FT-A, A901-6CZ-FT-D, ASR-920-24SZ-M, GRWIC-D-ES-2S-8PC, GRWIC-D-ES-6S, IE-2000-16PTC-G-E, IE-2000-16PTC-G-L, IE-2000-16PTC-G-NX, IE-2000-16TC-B, IE-2000-16TC-G-E, IE-2000-16TC-G-L, IE-2000-16TC-G-N, IE-2000-16TC-G-X, IE-2000-16TC-L, IE-2000-4S-TS-G-B, IE-2000-4S-TS-G-L, IE-2000-4TS-B, IE-2000-4TS-G-B, IE-2000-4TS-G-L, IE-2000-4TS-L, IE-2000-8TC-B, IE-2000-8TC-G-B, IE-2000-8TC-G-E, IE-2000-8TC-G-L, IE-2000-8TC-G-N, IE-2000-8TC-L, IE-2000U-16TC-G, IE-2000U-16TC-GP, IE-2000U-16TC-G-X, IE-2000U-4S-G, IE-2000U-4TS-G, IE-2000U-8TC-G, IE-3000-4TC, IE-3000-4TC-E, IE-3000-4TC-E-INT, IE-3000-4TC-RF, IE-3000-8TC, IE-3000-8TC-E, IE-3000-8TC-RF, IE-4000-16GT4G-E, IE-4000-16T4G-E, IE-4000-4GC4GP4G-E, IE-4000-4GS8GP4G-E, IE-4000-4S8P4G-E, IE-4000-4T4P4G-E, IE-4000-4TC4G-E, IE-4000-8GS4G-E, IE-4000-8GT4G-E, IE-4000-8GT8GP4G-E, IE-4000-8S4G-E, IE-4010-16S12P, IE-4010-4S24P, IE-5000-16S12P, IR1821-K9, IR1831-K9, IR1833-K9, IR1835-K9, OM-IE-3000-8TC
