One component of a robust solution that, when paired with a base unit (part #89008 or #89009, sold separately), extends your VGA and 3.5mm audio signals up to 300 meters over a Cat5E UTP cable, and distributes the signal to up to 4 monitors, projectors, or displays. Ideal for applications when your VGA monitor needs to be placed beyond the average 30 meter VGA cable limitation, and/or you want to split the signal to multiple displays.
Driving a VGA signal over Cat5E helps you take advantage of your UTP cable infrastructure already there for a cost-effective and reliable installation. The TruLink VGA over Cat5 solution is ideal for applications when you need to place your computer in remote location. This is common in digital signage applications for retail stores, houses of worship, classrooms, and boardrooms where you need video presentation in one room, but want the computer to be out of sight and in a safe and secure environment.
With the TruLink VGA + 3.5mm audio over Cat5 Extender, you can place your display across the room, on another floor, or in another building while your computer remains in a convenient location.
- C2G TruLink VGA + 3.5mm Audio over Cat5 Extender - Remote Unit - video/audio extender
- Video/audio extender
- Form Factor
- External
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 300 m
- 13 cm x 11 cm x 2.5 cm
- 367 g
- 1-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Max Resolution
- 1280 x 1024
- 300 m
- 1 x network - RJ-45 , 1 x VGA (output) - HD-15 female , 1 x audio (output) - mini jack female
- RoHS
- Power Device
- External power adapter
- 13 cm
- 11 cm
- 2.5 cm
- 367 g
- Limited warranty - 1 year
