Overcome the usual 4.5-meter length limitation of the IEEE-1394 standard. With this active extension cable, you can now extend your current cable another 5 meters! This is ideal for any situation where your device needs to be placed some distance from your computer. Compatible with 1394-1994 standards, this cable is fully interoperable with the FireWire standard.
Data transfer rates up to 400 Mbps are supported and you can daisy-chain up to 5 active extension cables to extend the distance of your cable an additional 25 meters! It is Plug-and-play and hot-swappable.
- C2G 5m 1394A Active FireWire Extension Cable - IEEE 1394 (FireWire) extender - Firewire
- Form Factor
- External
- Data Transfer Rate
- 400 Mbps
- Data Link Protocol
- Firewire
- Max Transfer Distance
- 5 m
- Form Factor
- External
- Connectivity Technology
- Wired
- Firewire
- 400 Mbps
- 5 m
- 1 x FireWire - 6 pin female
- RoHS
