C2G 15m LC/SC Duplex 62.5/125 MM LSZH Fibre Cable
Quicklinx: 9C90WS00 Mfr#: 85459
With LC to SC termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fibre connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The SC connector features a push-pull locking system.
The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures.
This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical.
The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
Each cable is 100% optically inspected and tested for insertion loss before you receive it.
Connector 1: (1) LC Male
Connector 2: (1) SC Male
  • Warranty Details
    This product carries a lifetime warranty
  • Jacket Rating
  • Jacket Design
    A pull-proof jacket design surrounds the popular 62.5/125 multimode fibre, immune to electrical interference
C2G LC-SC 62.5/125 OM1 Duplex Multimode PVC Fiber Optic Cable (LSZH) - patch cable - 15 m - orange
Patch cable - OM1
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free
Length
15 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x SC multi-mode - male
Connector (Second End)
2 x LC multi-mode - male
Orange
Network Cable Type
Patch cable - OM1
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
62.5 / 125 micron
Halogen-free
Length
15 m
Orange
Connector
TIA/EIA-455-171A
