C2G 1m Cat6 550 MHz Snagless Patch Cable - Orange
Quicklinx: 6BSTWS00 Mfr#: 83574
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated RJ-45 connectors provide a secure connection, minimizing interference and maximizing signal quality.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it suitable for various networking environments. The T568B wiring scheme and UTP technology help reduce crosstalk, ensuring high performance for critical network applications.
  • Universal compatibility
    Designed to meet RoHS compliant standards, this network patch cable is compatible with PCs and supports a wide range of networking equipment. Its universal design ensures easy integration into existing network setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
1 m
Orange
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
