C2G 0.5m Cat6 550 MHz Snagless Crossover Cable - Red
Quicklinx: 6BSKWS00 Mfr#: 83556
Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
  • Enhanced connectivity
    The Cat6 Booted Unshielded (UTP) Crossover Patch Cable by C2G is designed to facilitate direct peer-to-peer connection between PCs, allowing for seamless data transfer and file sharing without the need for a network switch or hub.
  • High-quality transmission
    With a tested frequency of up to 550 MHz and featuring 24 AWG wires, this crossover cable ensures reliable data transmission and minimal signal interference, making it suitable for various networking applications.
  • Durable design
    Constructed with a PVC jacket and gold-plated connectors, this cable is built for durability and reliable connectivity, ensuring a secure connection with optimal signal clarity.
C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 50 cm - red
Crossover cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
50 cm
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
