For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality 24 AWG wire and a durable PVC jacket. The gold-plated RJ-45 connectors provide a secure link between devices, minimizing potential connectivity issues. -
Optimized performance
Designed to support the demands of CAT 6 performance, this patch cable features minimized Near-End Crosstalk (NEXT) and reduced structural return loss (SRL), ensuring high-speed data transmission and improved signal quality for your network. -
Universal compatibility
With T568B wiring scheme and compliance with RoHS and TIA/EIA-568-B.2-1 standards, this network patch cable is built to work seamlessly with PC systems, making it a versatile choice for a wide range of network applications.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 30 cm - grey
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded, minimised Near-End Crosstalk (NEXT), reduced structural return loss (SRL)
- Length
- 30 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Impedance
- 100 Ohm
- Plated Connector
- Gold
- Length
- 30 cm
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, TIA/EIA-568-B.2-1
