C2G .5m Cat6 550 MHz Snagless Patch Cable - Grey
Quicklinx: 6BPDWS00 Mfr#: 83365
Length: 50cm
Colour: Grey
More than 50 In Stock
£2.98 ex VAT
£3.57 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection for uninterrupted network performance.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it suitable for various networking environments. The T568B wiring scheme and CAT 6 category compliance ensure it meets stringent network requirements.
  • Universal compatibility
    Designed to be compatible with PCs, this network patch cable features male RJ-45 connectors on both ends, facilitating easy and versatile connections between a wide range of devices and network components.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 50 cm - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
50 cm
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 50cm
Colour: Grey
Brand: C2G
