Buffalo's BS-MP series of 10GbE switches offers an easy, cost-effective and energy-efficient way to extend your business network at blazing speeds. Plug and play installation requires no additional software or configuration; simply plug your network-ready devices into one of the available Ethernet ports. Each AUTO-MDIX port automatically detects and configures the correct connection while optional jumbo frame support and full duplex operation provide maximum performance. This switch is a perfect complement to the TeraStation 5010 line of NAS devices which has up to 2 native 10GbE ports and is compatible to 2.5, 5 and 10 GbE. Along with 802.3az Green Ethernet technology, the BS-MP series includes intelligent Power Control, an energy conservation feature that monitors the activity status of each port to reduce the total power consumed. Its durable, metal chassis has holes and comes with rack mounting accessories for easy wall- /rack-mounting or rubber feet for placement on a desktop.
- BUFFALO BS-MP20 Series BS-MP2012 - switch - 12 ports - rack-mountable
- Switch - 12 ports
- Enclosure Type
- Rack-mountable
- Subtype
- 10 Gigabit Ethernet
- Ports
- 12 x 100/1000/10000
- Performance
- Latency: 10 µs , Backplane speed: 240 Gbps , Data transfer rate: 120 Gbps
- Capacity
- Buffer capacity (MB): 2
- MAC Address Table Size
- 16000 entries
- Jumbo Frame Support
- 9216 bytes
- VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, packet filtering, store and forward, MAC address filtering, full duplex mode, Quality of Service (QoS), Energy Efficient Ethernet, loop prevention, Link Aggregation, VLAN management
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
- Power
- AC 100 - 240 V (50/60 Hz)
- 33 cm x 23 cm x 4.4 cm
- 2.57 kg
- Localisation
- Europe
- 3 years warranty
- Switch - 12 ports
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Ports
- Performance
- Capacity
- 16000 entries
- 9216 bytes
- 12 x 10GBase-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 42 Watt
- Rack Mounting Kit
- Included
- Plug and Play, FCC Class A certified, UL, CB, IC Class A, VCCI Class A
- Localisation
- Europe
- 33 cm
- 23 cm
- 4.4 cm
- 2.57 kg
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 10 - 85% (non-condensing)
