Extend your existing wi-fi around your home using ultrafast dual-band 11ac 2600 technology. Perfect for all wi-fi devices.
Wi-Fi doesn’t reach?
Extend your wi-fi around your home
Want dual-band reliability and speed?
Connect your 11ac dual-band Wi-Fi extender to your existing wireless broadband
Prefer uninterrupted media streaming?
11ac dual-band Wi-Fi is ideal for downloading music, streaming HD content or for playing online games
BT Wi-Fi Extender AC2600 features
- Works with all broadband providers.
- Extends the range of your existing wi-fi.
- Gigabit Ethernet port for connecting devices.
- Connects to your hub or router with the push of a button.
- Easy set up with lights to help choose the best position.
- Dimable LED lights.
- Intelligently chooses between 2.4 or 5GHz bands to optimise your wi-fi experience.
- Supports UHD/HD video streaming.
- Builds a secure encrypted network - no need for configuration.
- Unique passwords for enhanced security.
- BT 2600 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Power
- AC 200-264 V (50/60 Hz)
- 8.35 cm x 8.15 cm x 14.7 cm
- 331 g
- 8.35 cm
- 8.15 cm
- 14.7 cm
- 331 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1733.3 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Reset button, WPS button
- Encryption Algorithm
- WPA, WPA2
Aerial
- Antenna
- External
- 1 x 1000Base-T - RJ-45
- Voltage Required
- 10.1 Watt
- -10 °C
- 45 °C
- 10 - 90%
