Works with any Broadband provider
BT's Mini Wi-Fi Home Hotspot 600 Kit has been designed to work with any service provider to make sure everyone can make the most of their Broadband at home or in the office.
What does BT’s Mini Wi-Fi Home Hotspot 600 Kit give you?
Connect any wired or wireless device to your broadband anywhere in your home or office with our powerline technology and enjoy the full broadband experience.
Plug & Play - No install necessary, just instant access to your broadband anywhere in the home or office!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT’s Mini Wi-Fi Home Hotspot 600 Kit, you are able to connect any wired or wireless devices wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Mini Wi-Fi Home Hotspot 600 Kit supports all your online needs.
Simple to use
BT’s Mini Wi-Fi Home Hotspot 600 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience.
Make the most of your Broadband
BT's Mini Wi-Fi Home Hotspot 600 Kit from BT offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, generating Wi-Fi where your router doesn't reach or high speed streaming throughout your home, BT's Mini Wi-Fi Home Hotspot Plus 600 Kit can be used to help make the most of your broadband at home or at work.
Compatible with other technologies
BT's Mini Wi-Fi Home Hotspot Plus 600 Kit works seamlessly with all other BT Broadband Extender products to create your new network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with any existing Powerline network. The Mini BT Wi-Fi Home Hotspot 600 Kit utilises HomePlug AV500 Powerline technology and can be fully integrated with an existing AV200 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Simple to use
BT's Mini Wi-Fi Home Hotspot 600 Multikit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience. -
BT's Mini Wi-Fi Home Hotspot 600 Multikit from BT offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, generating Wi-Fi where your router doesn't reach or high speed streaming throughout your home, BT's Mini Wi-Fi Home Hotspot Plus 600 Multikit can be used to help make the most of your broadband at home or at work. -
BT's Mini Wi-Fi Home Hotspot 600 Multikit works seamlessly with all other BT Broadband Extender products to create your new network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with any existing Powerline network. The Mini BT Wi-Fi Home Hotspot 600 Multikit utilizes HomePlug AV500 Powerline technology and can be fully integrated with an existing AV200 network in your home.
