Extend your Wi-Fi anywhere in your home
The Wi-Fi Home Hotspot Flex 600 Kit offers high performance Homeplug powerline adaptor and a Wi-Fi Home Hotspot designed to increase the range of your broadband in the home.
Wi-Fi doesn't reach?
Use your home's power sockets to create a secure Wi-Fi Hotspot.
Need high-speed internet all over your home?
Ideal for streaming HD / 3D TV or online gaming via an ethernet cable.
Want great Wi-Fi for your phone or tablet?
Extend your broadband to any wired or wireless device.
- Uses your home’s electrical wiring to extend your broadband network anywhere in the house
- Simple push-button Wi-Fi connection set-up with hotspot
- Wi-Fi cloning function to clone your router’s name (SSID) and wireless key
- Works with all broadband providers
- Two Ethernet ports for multiple wired devices
- Link with other HomePlug AV powerline adaptors
- N150 wireless technology
- AV600 powerline technology
- Compatible with AV200 and AV500 technology devices
- Uses latest AV600 technology for smooth multiple HD / 3D streaming
- Secure wireless network – no configuration necessary
- Pass-through socket
- Works out of the box
- BT Home Hotspot Flex 600 - Kit - powerline adapter - Wi-Fi - wall-pluggable
- Powerline adapter - 2-port switch (integrated)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Data Transfer Rate
- 150 Mbps
- Capacity
- Nodes: 16
- Remote Management Protocol
- HTTP
- WPS
- IEEE 802.3, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power
- AC 230 V (50 Hz)
- 6.6 cm x 7 cm x 7.6 cm
- 110 g
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- 150 Mbps
- Capacity
- Nodes: 16
- HTTP
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 40-bit WEP, TKIP, WPA, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- WPS
- Status Indicators
- Power, LAN, wireless, link/activity
- LAN: 1 x HomePlug AV - power , LAN: 2 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230 V (50 Hz)
- 4.7 Watt
- Included Accessories
- Broadband Extender Flex 600
- Cables Included
- 1 x network cable
- 6.6 cm
- 7 cm
- 7.6 cm
- 110 g
- Shipping Width
- 20.8 cm
- Shipping Depth
- 11 cm
- Shipping Height
- 15.7 cm
- Shipping Weight
- 602 g
- 0 °C
- 40 °C
- 10 - 90%
