Brother RJ-3050 Direct Thermal Printer
Quicklinx: CLMGWS00 Mfr#: RJ3050Z1
Our RJ-3000 Series portable printers are smaller and lighter than ever before. They provide the perfect on-person device for mobile workers needing a 2" or 3" printing solution - from emergency services and field sales to delivery drivers, engineers and traffic wardens. The RJ-3050 can print up to 3" receipts, quotes and labels on the spot. They're also fast, saving everyone valuable time and money.
Its thermal printing technology means users don't have to worry about ink or toner, while its IP54 certification-the toughest tests against dust and water-means you are assured of its continued reliability whatever the conditions. Plus ZPL compatibility also allows existing applications for label/receipt printers to work with the RJ device.
  • Fast print speed of up to 5 ips
    Faster transactions can mean less wasted time, higher productivity, and increased customer satisfaction.
  • Tough construction
    IP54 certification and 6 feet drop protection mean that water, dust, or drops won't affect the printer's operation under normal conditions.
  • Versatile functionality
    One mobile printer can be used for different mobile applications.
  • Ergonomic design
    Easy to load media and intuitive interface controls.
  • Low maintenance costs
    Highly reliable direct thermal technology uses fewer moving parts than other printing technologies. Fewer moving parts mean fewer parts to fail.
  • Low consumable costs
    There is no ink or ribbons to replace. The only consumable is the media.
  • Higher memory capacity
    Larger print buffer for increased throughput and more memory to store optional fonts.
  • 203 dpi resolution
    Ensures compatibility with existing mobile applications.
  • Wide selection of resident and downloadable fonts
    Enhance your output with Brother's wide selection of fonts.
  • Fanfold media capability
    External media slot in the back of the printer for warehousing applications.
Brother RuggedJet RJ-3050 - receipt printer - B/W - direct thermal
Printer Type
Receipt printer - direct thermal - B/W
Portable
610 g
Max Media Size
Roll (8 cm)
Min Media Size (Custom)
25 mm
Max Media Size (Custom)
80 mm
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0, Wi-Fi(n), Bluetooth 2.1 EDR
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
32 MB
Language Simulation
EPSON ESC/P, ZPL II, EPSON ESC/P Raster, Comtec Printer Control Language (CPCL)
Barcodes
Code 39, GS1 DataBar, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, GS1 DataBar Expanded, GS1 DataBar Limited
Media Type
Labels, receipt paper
Fonts
Helsinki, Letter Gothic Bold, Gothic
Print server
Required 1 Lithium Ion Included Qty 1
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Android 2.3 or later, Apple iOS 5.0 or later, Microsoft Windows Server 2012 R2, Windows 8.1
3-year warranty
113 cm x 18.6 cm x 8 cm
Printer Type
Receipt printer - direct thermal - monochrome
Printer
Print Speed
Up to 127 mm/sec
Wireless
203 dpi
Language Simulation
Fonts
Barcodes
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
32 MB
Media Handling
Media Type
Max Media Size
Roll (8 cm)
25 mm
80 mm
Media Sizes
Roll (8 cm), Roll (2.5 cm)
Max Printing Width
72 mm
Max Printing Length
1 m
Media Thickness Range
0.058 mm - 0.17 mm
Roll Maximum Outer Diameter
66 mm
Roll Core Diameter
12.7 mm
Media Feeders
1 x manual - 1 roll - Roll (8 cm)
Print server
1 x USB 2.0 - 4 pin mini-USB Type B
Belt clip
IP54
No power supply
Lithium Ion
Required Qty
1
Included
1
Run Time (Up To)
5300 pages
Limited warranty - 3 years
-10 °C
50 °C
10 - 90% (non-condensing)
113 cm
18.6 cm
8 cm
610 g
