Brother QL500 Label Printer
Quicklinx: 4525WS00 Mfr#: QL500AZU1
The Brother QL-500A Label Printer has taken label printing to a new level. Whether you need one label or many labels, it's the fastest, easiest and most versatile way to print labels directly from your PC. Perfect for printing address & shipping labels, banners & signage, this machine has unique label flexibility and can print on both die-cut peel-off labels or continuous length tape.
Brother QL-500A - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.3 kg
United Kingdom
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 90 mm/sec - B/W - Roll (6.2 cm) , Up to 50 labels/min - B/W - Roll (6.2 cm)
Max Resolution (B&W)
300 dpi
Cutter
USB
Media Type
Labels, continuous forms, CD/DVD labels
Compatible Tapes
DK tape
Microsoft Windows 98 Second Edition, Microsoft Windows 2000 Professional, Microsoft Windows Millennium Edition, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.1 - 10.4.7
3-year warranty
14.6 cm x 19.6 cm x 15.2 cm
Printer Type
Label printer - direct thermal - monochrome
United Kingdom
Printer
Print Speed
Up to 90 mm/sec - B/W - 300 dpi - Roll (6.2 cm) , Up to 50 labels/min - B/W - 300 dpi - Roll (6.2 cm)
Built-in Devices
Cutter
Wired
USB
300 dpi
Cutter
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (2.9 cm), Roll (1.2 cm), Roll (6.2 cm)
Max Printing Width
59 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
1 x USB - 4 pin USB Type B
1 x USB cable
Power supply - internal
Frequency Required
50/60 Hz
Additional Requirements
CD-ROM, SVGA monitor, USB port
System Requirements Details
Windows 98 SE - Pentium - 266 MHz - RAM 64 MB - HD 70 MB , Windows 2000 Pro - Pentium - 266 MHz - RAM 128 MB - HD 70 MB , Windows XP Home Edition - Pentium - 266 MHz - RAM 128 MB - HD 70 MB , Windows XP Professional - Pentium - 266 MHz - RAM 128 MB - HD 70 MB , Windows ME - Pentium - 266 MHz - RAM 64 MB - HD 70 MB
Limited warranty - 3 years - carry-in
10 °C
35 °C
20 - 80%
14.6 cm
19.6 cm
15.2 cm
1.3 kg
Ink (8)
4525 Brother Large Address Labels In Stock £7.94
4525 Brother DK Continuous White Labels In Stock £13.90
4525 Brother Shipping 62 x 100mm 300 Labels In Stock £13.73
4525 Brother P-TOUCH Yellow Paper- 62mm In Stock £13.80
4525 Brother p-touch White Paper - 62mm In Stock £12.60
4525 Brother Paper Roll (6.2 cm x 30.5 m) In Stock £10.46
4525 Brother Non Adhesive Paper Tape 54mm In Stock £11.96
4525 Brother DKBU99 Printer Label Cutter (2 Pack) In Stock £6.94
Other bundles (2)
4525 Brother BROTHER DK-22212 TAPE 62MM WH. In Stock £35.76
4525 Brother P-TOUCH TAPE PAPER 29MMX30.48M In Stock £6.56
Resources
The following resources are available for the Brother QL500 Label Printer
