Keep everything present and correct with the QL-570, which quickly produces durable labels via your PC that can help to make sure you never misplace a file or lose important documents ever again.
This thermal address label printer delivers professional results with one click, so it's a handy solution for any business that wants to stay organised.
Simply connect to your PC or Mac via USB, design your label then print. It delivers high-quality results up to one metre in length using a continuous roll, so you can easily create everything from name badges and divider table labels through to signage and shipping labels.
Whether you're printing hundreds of labels or just one, the QL-570 offers perfect results, time after time.
- Brother QL-570 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.13 kg
- Max Media Size
- Roll (6.2 cm)
- Print Speed
- Up to 68 labels/min , Up to 90 mm/sec
- Max Resolution (B&W)
- 300 x 600 dpi
- Cutter
- Interface
- USB
- Barcodes
- Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
- Media Type
- Labels, address labels, file folder labels, CD/DVD labels, shipping labels
- Compatible Tapes
- DK tape
- Styles & Effects
- Vertical, Mirror, rotated text
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.3.9 - 10.4.10
- Microsoft Certification
- Works with Windows Vista
- 3-year warranty
- 13.4 cm x 20.8 cm x 14.1 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 68 labels/min - 300x300 dpi , Up to 90 mm/sec
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- USB
- 300 x 600 dpi
- Styles & Effects
- Auto Cutter
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 59 mm
- Max Printing Length
- 914 mm
- Connections
- 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities, P-touch Address Book 1.1 for Windows, P-touch Editor 5.0 for Mac OS, P-touch Editor 5.0 for Windows
- OS Required
- Additional Requirements
- CD-ROM, USB port
- Limited warranty - 3 years - carry-in
- 13.4 cm
- 20.8 cm
- 14.1 cm
- 1.13 kg
