From file dividers to cabinets, office equipment to name badges, having everything clearly labelled is a sure-fire way to get your workplace organised and running smoothly.
With the PT-D450VP, you can quickly generate labels up to 18mm wide, either using the printer's own PC-style 'QWERTY' keyboard and high resolution backlit display to create them direct or sending your designs via your PC. It also comes complete with its own handy carry case, 18mm black on white label tape and adapter.
PC-connectable
Use stand-alone, or connected to a PC or Mac for added design capabilities. -
Split-back tapes
Uses durable, easy-peel tapes in 4 different widths up to 18mm (approx. ¾"). -
One-touch keys
Easily add frames and other formatting features. -
Large memory
Save up to 50 commonly used labels and help save time with reprinting. -
Specialty templates
Print labels for asset management, cable labeling and more.
- Brother P-Touch PT-D450VP - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- 740 g
- Max Media Size
- Roll (1.8 cm)
- Max Media Size (Custom)
- 18 mm
- Print Speed
- Up to 20 mm/sec
- Cutter
- Interface
- USB
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Fonts
- 14 fonts
- Styles & Effects
- Vertical, underline
- 5 line printing
- Display Resolution
- 320 x 120
- Keyboard
- QWERTY / 65 keys
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8.x, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- Enclosure Colour
- Black
- 18.8 cm x 17.7 cm x 7.2 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
- Enclosure Colour
- Black
Printer
- Print Speed
- Up to 20 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- Interface
- USB
- Fonts
- 14 fonts
- Styles & Effects
- 5 line printing
- 320 x 120
- Auto Cutter
- Keyboard
- QWERTY / 65 keys
- Repeating Printing
- 5000 copies
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (1.8 cm)
- 18 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Max Printing Width
- 15.8 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (1.8 cm)
- Connections
- 1 x USB
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable
- Media Included
- 1 18 mm x 4 m black on white TZe laminated tape cassette
- Power Device
- Power adapter
- OS Required
- System Requirements Details
- Windows Vista/7/8/8.1 - RAM 512 MB - HD 70 MB , MacOS - RAM 2 GB - HD 500 MB
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
- 18.8 cm
- 17.7 cm
- 7.2 cm
- 740 g
Ink (16)
Brother TZES221 Black on White 9mm | In Stock | £10.87 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.51 |
Brother TZE-651 24MM BLACK ON YELLOW | In Stock | £16.67 |
Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) | In Stock | £11.14 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.30 |
Brother Tape Black on Yellow 6mm | In Stock | £7.48 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.14 |
Brother Tape Black on Yellow 12mm | In Stock | £11.40 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.41 |
Brother 12mm Black on White Tape | In Stock | £11.40 |
Brother Tape Black on Clear 9mm | In Stock | £7.48 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £9.85 |
Brother TZESE4 Black on White 18MM Security Tape | In Stock | £26.24 |
Brother 12mm Blue on White Tape | In Stock | £9.85 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.80 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.41 |
Other bundles (1)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.31 |
